![]() | Home > Maintenance & Mods (L405) > Oil Leak |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
The coolant looks clean. SDV8 AB MY 2020
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 372 ![]() ![]() ![]() |
I bought a camera for the purpose of locating leaks.
I have now ordered one.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1413 ![]() ![]() |
If you suspect oil filter, check the oring is in the correct position and not damaged/flat etc and ensure it's not cross threaded when you re-instal, and use a Torque wrench!.
I have used the endoscope. I don't think it is the filter. The dripping is increasing.
Just remembered I took out an extra warranty. So will ask if the oil leak is covered before I do too much. SDV8 AB MY 2020
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1816 ![]() ![]() ![]() |
Could also be the 2 dreaded Orings on the rear of the Engine best done when cooler off.
Found that Christian is about 2 hours from me.
Garage will check next week.
The importance of having the car on flat ground. I was in a car park this evening and remembered to check the oil level before driving home. I am only down 1 mark after topping up. So I haven’t lost as much oil as I thought I had.
Car was at the garage today. It will be fixed on the extended warranty. They will call Monday to arrange. SDV8 AB MY 2020
