![]() | Home > Technical (L322) > 4.4 TDV8 Slow coolant Leak Fix |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2687 ![]() ![]() |
Mine's top hose o-ring is now a snug-fitting 45 mm x 3.5 mm in Viton75. A slightly smaller supposedly 45x3.5 but suspected BS224 pair were first supplied which I didn't try but today found to float excessively in the housing prior to fitting a real 45x3.5 sourced from a different supplier to the bearing retailer. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3553 ![]() ![]() ![]() |
I have some coolant dripping down the back of the bell housing. Where should I go first? EGR? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
It's a possibiliy but an inspection with an endoscope will confirm. Mine's been leaking from the EGR cooler for 2+ years and I just keep topping up the coolant as the cost of replacing the EGR cooler is not worth it. If it gets worse I'll have to have it done but so far it's been just a contant small leak. 2012 TDV8 Vogue (L322) |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 104 ![]() ![]() ![]() |
GraemeS can you confirm the size for both the stat housing pipes is 45X3.5 , mines slightly seeping and if i'm draining it down a bit I'll do both of them , agree with a list of oring sizes would be a very useful wiki .
Both are indeed the same size. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
Could also be the EGR cooler. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 339 ![]() ![]() |
I am just tagging on here as I also have a slow coolant leak which we cannot diagnose (2012 4.4 TDV8)
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
Where is the Egr cooler hose o ring located, what about the size? 2011 Vogue SE 4.4 TDV8 Last edited by Mfcetin on 12th Mar 2025 2:58pm. Edited 1 time in total |
I think I found one of my coolant leaks. It is the hose on the right rear side of the plenum.
Kasandrich Member Since: 16 Mar 2025 Location: Braintree Essex Posts: 2 ![]() ![]() |
It's reassuring to know I'm not the only one with a minor coolant leak on an L322 4.4tdv8 |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
In changing the alternator I've noticed the push fit fitting on the bottom of the expansion bottle is weeping slightly so that's another possible source.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 138 ![]() ![]() ![]() |
You’re not even the only one in Braintree ![]() |
Where abouts in Braintree are you? I'm in victoria street right in the town centre |
I’m on the fairview estate |
