Home > In Car Electronics (L405) > SOS limited functionality - battery replaced but not fixed
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Hi Captain_67, check your PM's re the iid tool. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686834 29th Feb 2024 10:31pm
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Taking the trim panel off is a pain as there are two bolts at the top of the trim panel and to get to those you need to remove the center screen surround and the one on the right hand side of the steering wheel.
You then need to pull up the dash surround to finally get access to the bolts.
Then you also need to pull off the black panel on the side of the transmission tunnel as this has two prongs that hook into the the trim panel. You don't need to fully remove it, just loosen it off so you have enough space to unhook the trim panel.
None of it is hard, it is just it feels like you can easily break the fixing clips, especially on the dash surround. 2016 AB SDV8 Barolo black - Sadly sold
1995 RR Classic - Ex Police car - Now Sold
1994 RR 4.2 LSE - Long gone
Post #686868 1st Mar 2024 10:58am
Captain_67
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Thank you for the reply you have confirmed my suspicions and it looks like it’s a slow and steady job with no short cuts. I guess LR needed to make the TCU difficult to access. Did you need to have the TCU reprogrammed after replacing the battery and if so is this a main dealer job
Thanks
Post #686870 1st Mar 2024 11:24am
lambo911
I still have the error code so a trip to the dealer is needed to get it reset with an IDD 2016 AB SDV8 Barolo black - Sadly sold
Post #686871 1st Mar 2024 11:38am
4RRS
Not sure IID can do it, I've never seen the option on mine, but SDD will do upto pre facelift MY 2017, then it's pathfinder or Topix cloud. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686877 1st Mar 2024 12:15pm
lambo911
is SDD something you can buy for a sensible price ? 2016 AB SDV8 Barolo black - Sadly sold
Post #686880 1st Mar 2024 12:33pm
4RRS
It's a £3K+ yearly subscription for the genuine item, cracked copies are available which will do the job perfectly, you will need a VCI and a laptop however. If you have a laptop maybe look at :-
https://www.ebay.co.uk/itm/375206844313 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686882 1st Mar 2024 12:37pm
lambo911
Thanks.
Do you need one with a hard drive, or can you just load the software onto an existing laptop, like you can with BMW stuff ? 2016 AB SDV8 Barolo black - Sadly sold
Post #686885 1st Mar 2024 12:51pm
4RRS
It's simple to install the legit version which you can download for free from topix, if you don't have a topix subscription you will need to crack it, which is a little harder. Dpending how long you want to play with it, you maybe just better paying a little more and having the operating system and cracked programme pre-installed on the hard drive and then just swap it out with your laptop hard drive.
Obviously I never did any of this (ahem) as I now have a legit topix subscription.
I guess the other option is find an indie with an SDD subscription. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #686887 1st Mar 2024 1:49pm
Captain_67
Just for information
Battery replaced but U2109 fault still present
I spoke to Inschape Chester but they refused to carryout the reset of the Telemetry ECU because I had changed the battery.
I spoke with Hatfields in Shrewsbury and they said drive it for another hour and if that does not fix it book it in and they will need 2 hours to diagnose it at a cost of £377.40
Does anyone now if the ECU can be coded out as cutting the wires and throwing the module in the bin is unlikely to work either.
Whilst I understand some of this is done for security reasons I think the changing of a battery should not be deemed as a task that only a main dealer is allowed to do and even if it is there should be a small admin charge not 2 hours of labour.
Post #687164 4th Mar 2024 2:56pm
Fifth Horseman
Latest version of the IIDTool software has the TCU battery test function (at least when connected to a 2018 vehicle, so should be ok for earlier ones). I've not had cause to use it so can't verify it though.
Post #687170 4th Mar 2024 3:44pm
lambo911
Whilst my car was in for an MOT at the main dealer today they cleared the fault for me free of charge.
So basically, you can't just change the battery, you also need to tell the car it has a new battery before you can clear the fault. 2016 AB SDV8 Barolo black - Sadly sold
Post #687261 5th Mar 2024 1:51pm
MrBullet131
I've just changed mine (L494) I have Icarsoftmax diagnostics. Today I couldn't find how to tell the TCU it's had a new battery. I'm gonna try again tomorrow. I'll keep you posted. In the mean time if your desperate, give Ian Barclay a ring, they are in Birkenhead, been around for years and have the latest LR diagnostics.
Post #720369 25th Jun 2025 5:24pm
MrBullet131
I have a L494, I fitted a new battery pack in my TCU today. The fault stayed on the dash, heres what the diagnostics codes. I am using Icarsoft max, I couldn't figure out hoe to tell the TCU its had a new batter pack. I'll try again tomorrow and keep ya'all posted.
The telematics control unit fault code B1a01-14 indicates a problem with the TCU's internal battery circuit. Specifically, it suggests an open circuit, high resistance, or a failure of the internal battery itself.
Fault code B117a-14 in a Telematics Control Unit (TCU) typically indicates a problem with the vehicle's communication and connectivity system, specifically related to the TCU itself or its communication with other modules. This could be due to a faulty TCU, a problem with the wiring harness, or issues with the Ethernet circuit within the TCU.
The fault code B116E-15 in a Telematics Control Unit (TCU) typically indicates a problem with the high-speed CAN bus (powertrain) circuit, specifically a short circuit to ground, short circuit to power, open circuit, or high resistance.
The telematics control unit fault code B116D-15 indicates a problem with the internal battery circuit or the backup battery within the telematics control unit (TCU).
These are the 4 codes and Googles answer, could the unit itself be faulty, I know I'm inexperienced but that would be my guess. The nuts were very loose when I 1st got to them.
Post #720370 25th Jun 2025 5:28pm
