Home > Technical (L322) > TDV8 2010 Top Rad Hose 4 Way Coupling - Please Help Identify
pcourtney
I bought one yesterday just to have in my spares box, as it's gonna happen one day
F Type Adapter Female to Female TV Aerial Extension Adapter F Type Female to Female Coax Connector F Type RG6 Coax Cable Satellite Connector F Connector Coupler Joiner Gender Changer
Post #687059 3rd Mar 2024 3:55pm
GraemeS
Australia
I tapped a 1/8 NPT thread then fitted a 1/8" NPT to 3/8" barb and fitted a 90 deg 3/8" to 3/8" barb at the other end as that fitting also easily breaks, to use 3/8" hose. When I recently replaced all the coolant hoses I retained my modified coupling, hose and the 90 deg at the other end rather than fit fragile originals.
Post #687091 3rd Mar 2024 8:56pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
I broke another connection on that brittle pipe. Any ideas how to fix it?
I really dont wanna pay 160 euros for the whole pipe assy.
All LR parts so expensive in Germany 😬
 2011 Vogue SE 4.4 TDV8
Post #692263 9th May 2024 4:19pm
Mfcetin
I had a closer look and its a connection element between two pipes. Some sort of stent.
Will look at the hardware store if I can find a similar connector.
This part is part of the other softer pipe, right? It will not come with LR029140? 2011 Vogue SE 4.4 TDV8
Post #692265 9th May 2024 4:26pm
Mfcetin
That stent is broken. Unfortunately you cannot buy only this small part, comes with bunch of other hoses. If anyone needs here is the part number, LR022690
Post #692266 9th May 2024 4:43pm
Mfcetin
More research on this forum showed me that this connector is actually a fuel line quick connector, see discussion here
https://www.fullfatrr.com/forum/topic66149...t=lr022690
Available on ebay and amazon 2011 Vogue SE 4.4 TDV8
Post #692457 12th May 2024 2:55pm
Mfcetin
just to confirm that the correct size is this one
Post #692691 15th May 2024 11:31am
