![]() | Home > Maintenance & Mods (L405) > Trim ring |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
Well after 45 yes of marriage ( too late to change now) SWMBO declared she was cold so I told her to turn the temperature up on her side. “What was that little ring thing that fell off?” Never to be seen again - I can’t actually remember where I got them (all 3) can anyone remind me?
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 107 ![]() ![]() ![]() |
Geoff,
After investigation g I know where it’s gone - into the hole/void under the passenger seat and my big hands don’t fit, I’m not taking the seaT out to get it back. I just stuck the Autobiography badge on because I didn’t like the big blank space that was there. Not sure if the trim rings are magnetic if so I might try a magnet on a piece of string.
What am I thinking, it’s made of aluminium so a magnet will be of no use. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1525 ![]() ![]() ![]() |
The L460 will drive your OCD mad then with the big gap below screen!! |
It'll be a while yet - I read no really positive comments on here re: L460 Geoff |
Deffo cant find it so ordered Geoff |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 961 ![]() ![]() |
If you remove the four bolts securing the seat rails to the floor, you should be able to tip the seat back against the rear seat to gain access, without removing the seat or unplugging anything. Jonathan 2010 L322 5.0 SC Autobiography Black 2007 Defender 90 XS Hardtop |
Wouldn’t you just know it, retrieved the trim after giving it another go (it was in the hole in the floor) and of course just ordering replacements. When they arrive I’ll do the controls in the back and experiment to find how best to fix them in place. Geoff |
Geoff,
That is indeed what has happened, double sided tape dried out. I think I'll just use glue as its not likely I'll be removing them - well not intentionally that is |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442 ![]() ![]() |
We definitely need a "Like" button! ![]() |
