Home > Technical (L322) > Permanent fix for leaking throttle body pipe
Page 2 of 3 <123>
mgrover
how many orings did you use? did you remove the screen gasket and fit it manually or leave that in its normal place
also anyone knows how i can get the TB to shut so I can clean the Censored , its caked.
but i don't really wanna do it by hand and break anything. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671636 21st Aug 2023 11:32am
JCW
Four o rings and everything else exactly per Furnituremans’ instructions 👍 Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #671640 21st Aug 2023 11:53am
mgrover
cool will do same when it turns up thanks Smile Its actually a sport Sad
Post #671642 21st Aug 2023 11:58am
fmgl322
Germany
Evening all. I’ve discovered the source of my air leak and it’s the little hose connected to the throttle body elbow. Can anyone tell me what the dimensions are of this pathetic little piece of wisened old rubber once was on my car? It’s so brittle, when I removed it to check for markings/dimensions, it crumbled in my hand. Still, it gave me the chance to clean the rest of the system and, thanks to FM’s instructions, I’ll be going down the multiple o-ring route to seal it up for the foreseeable.
Thanks folks! -------------------------
2012 4.4 TDV8 Vogue
2001 Audi A2 1.4 16V
2019 Skoda Kodiaq (don't ask...)
Post #676448 25th Oct 2023 7:30pm
TomC-RRV8
Re: Permanent fix for leaking throttle body pipe
Furnitureman wrote:
Like nearly all 4.4 TDV8 owners the rigid plastic connector to the throttle body is leaking, it’s an awful design from the start and most look like this after several thousand miles
The problem is the seal inside really isn’t upto the job and the fit is so loose it’s comical it ever got past the design stage, I’ve been thinking for a while how to solve this issue and I think I’ve done it, this is my connector 2000 miles after the fix
The fix is so simple and costs under £20 and doesn’t involve PTFE tape, to fix this irritating issue you will need the following
Small flat blade screwdriver
7mm socket
3 75mm int diameter 3mm O Rings
To start remove the rubber intercooler pipe using the 7mm socket
Then undo the clamp on the small pipe top right of the connector and remove the pipe
Next in clip the electrical connector bottom left of the pipe
Finally pull out the metal retaining clip and remove the connector
This is what it looks like inside
The seals are usually misshaped and don’t form a great seal, just in front of the seal is a rigid plastic retaining ring to remove this use the small flat bladed screwdriver to pop the retaining lugs inwards like in the picture below
You can put the rigid retaining ring aside, next get the three 75mm O rings and slide them over the metal throttle body then fit the original seal as below
Finally re fit the rigid plastic part, re connect the plug and pipe and re fit the intercooler pipe, after 2000 miles mine is as clean as the day I did the repair
Hope this helps others if you do a search on eBay you will find the o rings
Just for clarification you refitted this without the plastic retaining clip that holds back the original green rubber seal? Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #677167 3rd Nov 2023 2:08pm
pcourtney
Thank you for the instructions, I bought a pack of 10 from Amazon, next day free delivery using Prime and for under a fiver - happy days to fix this stupid turbo elbow charged air leak
Keywords for searching on Amazon below :
Nitrile Rubber O-Rings 75mm OD 68.8mm ID 3.1mm Width, Metric Sealing Gasket, Pack of 10
Post #687044 3rd Mar 2024 12:27pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Please send a link
Post #687097 3rd Mar 2024 9:54pm
pcourtney
sure - but this is the .co.uk site for Amazon
https://www.amazon.co.uk/dp/B07G2VFJKY?psc...ct_details
Post #687117 4th Mar 2024 10:03am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Same question has been presented to the OP a few times now in 1 year and 3 months... -07 Stornoway Gray TDV8
Post #687152 4th Mar 2024 1:51pm
SFM
I like the idea of this fix, been quoted €280 for new connection and pipe!
Done mine 3 times now with ptfe tape, and it does make a big difference with the DPF readings.
Terrible design I think, anyway, this does seem a solution to the problem, well done for thinking “outside the box” for a cheap way of getting around this problem.
As said before, do you leave the retaining plastic ring out or not, do you smear the new o rings with oil to aid installation?
Post #687219 4th Mar 2024 9:18pm
pcourtney
I fitted 3 o-rings on mine, seems to be a much better fit, will check in 1000 miles Smile
Post #687227 4th Mar 2024 11:02pm
pcourtney
Post #687228 4th Mar 2024 11:02pm
DrRob
Sam's Motor and Machines covered this in his latest video.
Around 30min into the video Thumbs Up
?si=40Cnra4XK598sH6e Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #687248 5th Mar 2024 9:15am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
What I would like to add is to make sure all the tabs of the metal retainer ring sit in the groove in the throttle body, all the way around.
My elbow, the black plastic part, had a little soot on the outside, at 5-o'clock, so to say.
The green OEM seal (it looks like an X-ring, imo) was ok, as far as I could judge.
The metal retainer was a little stretched though, so when I fitted it without the elbow I noticed not all the tabs were in the groove.
So I bend the retainer in several spots and made the ends cross, in other words: the retainer diameter is now less than the throttle body groove diameter.
Now I'm sure all tabs are in the groove keeping the elbow in position. 2012 4.4TDV8
2000 Honda S2000
Post #690536 13th Apr 2024 7:47pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
The sensor on this pipe is quite loose on my car. Oil is dripping from around the sensor. Any ideas how to fix that? I really don’t have any RP faults but it is pretty annoying that it is so leaky there. And I surely dont wanna pay for the whole pipe, which costs around 400 euros in Germany 😬 2011 Vogue SE 4.4 TDV8
Post #691787 2nd May 2024 7:34pm
Page 2 of 3 <123>
