Home > Maintenance & Mods (L322) > Another issue to contend with...
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Whilst the car was parked up yesterday at work my headlamp wash wipe developed a mind of its own and ran continually until I finally had enough and pulled the battery after getting home.
looking at the wiring diagram I see that there is a fuse that powers everything before the relay so will be taking that out tonight to hopefully at least isolate the wash wipe system until I can get a better look at it. I'm assuming the relay is toast but I'm struggling to find any other than used via e-bay, which I'm not against using if I have to but with most second hand parts its a risk I'll end up doing it all over again.
other than main dealer does anyone know of a supplier?
believe the part is 61366904550
Cheers
Post #686910 1st Mar 2024 5:49pm
pcourtney
Fuse 28 Headlight Cleaning
https://www.fullfatrr.com/forum/topic69253.html
Post #686912 1st Mar 2024 5:54pm
pcourtney
I am looking as well for my drivers side Smile
Post #686913 1st Mar 2024 6:08pm
Discofish
pulled the fuse and everything is now still. contacted land rover and the relay is currently unavailable to order but the code is YWB000110 @ £69.47
just in case anyone needs one, thanks for the help all as usual Very Happy
Post #687281 5th Mar 2024 6:00pm
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
I just looked at JaguarLandRoverClassicParts and they are listing as in stock and available to order.
They seem to have a different set of parts availability to main dealer listing which always strikes me as odd.
https://parts.jaguarlandroverclassic.com/ywb000110-relay.html L405 2018 5.0 S/C
Post #687297 5th Mar 2024 9:08pm
Discofish
Interesting... that diagram implies it's mounted in a fuse box with other relays, but I've seen on other forums / videos that you need to dismantle the left hand end of the dash including the vent & cup holder as the relay is mounted more or less to the bulkhead...more investigation required
incidentally the replay shown in the videos and on eBay are all a brown/orange colour
Post #687317 6th Mar 2024 9:20am
pcourtney
There is probably also a BMW part for an X5 or something (in the 2002 era) that is basically the same relay but half the price Smile
Below is a photo head on of the 61366904550 part
Post #687329 6th Mar 2024 12:37pm
pcourtney
video Headlight Wiper Motor Relay Replacement
&ab_channel=AlanHowson
Post #687334 6th Mar 2024 1:09pm
