Home > Maintenance & Mods (L322) > Windscreen Washer Pump Access
mjdronfield
Can you get to the washer pump without taking the wheel off etc?
Looks like mine has stopped working, just got wipers but no water. Can’t hear the pump running.
Thanks
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #687285 5th Mar 2024 6:53pm
JayGee
If you turn the wheel outwards fully and undo the liner screws at the front it may be possible to squeeze in there but it's far easier with the wheel off. No pump sound - Fuse? 2012 TDV8 Vogue (L322)
Post #687286 5th Mar 2024 7:07pm
mjdronfield
Thanks. Not looked to be honest as might have wrongly assumed not that as the rear works… are the 3 pumps on separate fuses?
I’ll see what’s in the manual…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687291 5th Mar 2024 7:49pm
mjdronfield
Fuse 38 then… thanks for the info… teach me not to assume things 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687292 5th Mar 2024 7:55pm
mjdronfield
Might have to leave till later… the diagram doesn’t seem to match what’s there and the old fuses I have are much bigger 🤣… I know it’s a blue 15 amp, but could be any one… and I’m sure there are spare fuses there…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687327 6th Mar 2024 12:07pm
JayGee
Rotate the schematic 90 deg counter clockwise 2012 TDV8 Vogue (L322)
Post #687331 6th Mar 2024 12:50pm
mjdronfield
🤣 ah, I see….. got it now…. It’s not the fuse….
Looks like a new pump is in order….
Thanks
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687352 6th Mar 2024 4:37pm
JayGee
Does the rear wash and headlight wash work? 2012 TDV8 Vogue (L322)
Post #687355 6th Mar 2024 4:45pm
mjdronfield
The rear still works. Not tried the headlights. I understand you can swap connector and pipes to other pump as temp measure but if I’ve got to take wheel off I’d rather just do that and replace it. That said, I know it’s not ruled out everything beforehand. Looks like there are a few different pumps but I recon it’s DMC500040 from the diagram below….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687361 6th Mar 2024 6:30pm
Range Rover L322
Hi Mike
There are three pumps in there. Left hand big one is the windscreen washer - I changed mine recently. note
1) the other two pumps can be reversed as same.
2) to test headlight washer washer the lights must be on.
It's a simple job - watch this.
Best, Matt
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH (Ex LR Chief Technician)
Post #687376 6th Mar 2024 10:49pm
mjdronfield
Thanks. I ordered DMC500040, which I guessed was correct looking at the below. Less than £10 from John Craddock… hope that’s the right one then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #687380 6th Mar 2024 11:43pm
mjdronfield
Just fixed this. Managed to get enough access with the car in off road height. On mine the front washer pump was the far right one, the front any rear washer pumps are the same, as already mentioned above.
Cut the hose connector back a cm to get a good seal on the new pump.
Thanks for the advice. Not my pic below, that chap took the wheel off.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #688514 20th Mar 2024 3:39pm
