Home > Maintenance & Mods (L322) > How to remove this plug? Bleeding coolant system.
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Replaced the thermostat on my 5.0 L322 today but I'm having problems bleeding the system.
The workshop manual indicates the plug below needs to be removed / released but I can't work out how. All the other bleed screws are open & eventually the car begins to overheat at which point I shut it off. I can hear gurgling around this area so there is definitely air in the system. Anyone know how these types of plugs are released?
Post #643201 17th Sep 2022 2:59pm
Rackers
To answer my own questiion, the loop on the plug was broken bang smack in the middle. So, pushing it did nothing to release the catches on the plug. It is now out and the mission to bleed continues!
Post #643205 17th Sep 2022 3:22pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi Rackers, I know this is a really old post, but how did you get on bleeding out the air of your engine. I'm just about to embark on flushing the system and I can't find any bleed points at all, not even by the fill bottle. if you of anyone for that matter has under taken this job on the 5.0SC any advise would be mush appreciated.
Cheers in advance. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687603 9th Mar 2024 10:55am
Rackers
I had to get a pressure bleeder in the end, these things are a nightmare to bleed manually.
There is a manual here that explains how to do it but I wouldn't bother if you want to keep your sanity.
JagRepair.com
http://jagrepair.com › imagesPDF
NP10-V8JLR: AJ133 5.0-Liter DFI V8 Engine
http://jagrepair.com/images/Training%2520G...3eOnU0L4Zi
Cheers
Post #687604 9th Mar 2024 11:08am
PDC
Many thanks for that, maybe this job might be best left to a professional..... 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687611 9th Mar 2024 12:54pm
Rackers
It depends how patient you are, I bled manually (successfuly) once when I did the thermostat but the second time no good. Probably too much air as a result of opening up the water pump.
If you know someone with a compressor it's always handy to have the bleed kit!
Post #687615 9th Mar 2024 1:21pm
PDC
A bleed kit is £25 which I guess could go towards the mechanic's fee. But I was hoping that a mechanic that knew what he was doing could do it without using the vacuum as I'm not sure I like that solution as it crushes the coolant pipes flat as it sucks all the air out of the system. I figure on old hoses it might end up cracking them and putting them under more stress than needed. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687617 9th Mar 2024 1:34pm
Rackers
If it helps, on my 2010 the pipes didn't go completely flat/get crushed and are fairly robust. The workshop manual actually recommends the use of a vacuum bleeders as well.
Post #687620 9th Mar 2024 1:56pm
PDC
So did you find after using the vacuum pump that there was no need to bleed the system. This is what I'm worried about as I can't find any bleed points on the system. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687628 9th Mar 2024 3:53pm
Rackers
No need to bleed at all, it does the whole job for you.
Basic procedure would be:
Drain the coolant from the lowest point (I think its on the bottom of the rad if I'm recalling correctly)
Pop the vacuum pump on the coolant tank to pull the air out of the system.
Follow the instructions with the pump to refill (in a nutshell it uses the vacuum pulled from the system to fill the system with coolant with no air getting trapped).
It took me about 20 minutes excluding waiting for the coolant to drain out.
Post #687635 9th Mar 2024 6:03pm
PDC
Cheers, that has now given me the confidence to tackle the job myself after I have purchased the the vacuum kit. Thumbs Up 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687638 9th Mar 2024 6:38pm
Rackers
No problem, good luck!
Post #687639 9th Mar 2024 7:08pm
