![]() | Home > Technical (L405) > B1D55-Antenna 2 circuit |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
The DAB antenna is located in the rear spoiler. The connector may have become dislodged at some point. It's easy enough to remove the rear spoiler to take a look. Only a few bolts. Kev
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 149 ![]() ![]() ![]() |
When you say rear spoiler - do you mean the one at the top of the rear tailgate, so it opens with the tailgate? Not the sharks fin?
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1399 ![]() ![]() |
The DTC from WSM are below, maybe corrosion/water ingress etc?
Thanks! I see a little job coming up for a sunny day...
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1776 ![]() ![]() ![]() |
Hi ChrisJC,
Tailgate has dropped - which does bug me! So thanks for the tip.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1510 ![]() ![]() |
Kot, regarding the above picture with antenna / amp locations, what year is that WSM manual for?
Some serious corrosion, glad you found the fault.
Yup - the second set of WSM pictures match what I have - so all good.
Not sure VIN will make much difference ... |
Was going to put this in a different thread, but then thought keep it all together as its all relevant to the original post.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
clever |
( I'm just dumping info into here so it can be referred to if anyone needs it further down the line )
