![]() | Home > Technical (L322) > L322 2011 4.4 - Turbo Boost Pipe |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 306 ![]() ![]() ![]() |
You’ll probably need to do a little more homework to get the advice you’re looking for; track down the specific part at fault and then use search on here to find what others have done.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 703 ![]() ![]() ![]() |
Hi, nothing to do with your question but I do like your wheels, those 5 spokes really suit the car, at least from that angle.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
You'll need to determine which of the boost pipes on that side it is. Here's the diagram to confirm:
gone18751 Member Since: 28 Nov 2023 Location: None Posts: 17 ![]() ![]() |
Thanks a bunch for that. I am currently in Italy so will take it down to a garage to inspect. |
I am pretty sure they are from an X5. Even though the bolt pattern is the same, I was almost certain that I would need spigot rings but they mounted perfectly. They are Alessio rims.
Thanks a bunch for the excellent information ![]() |
Thanks for that info. I did check his video out a few weeks ago and am seriously thinking about doing a EGR & DPF delete and mapping them out. |
Thanks for the tip on the wheels, I'll look around.
It took me a while but I got them in the end.
