Home > Technical (L322) > L322 wipers and attachment
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Hi gents,
What's the best wipers for the l322?
Search suggests bosch 808s from a thread a few years ago but worth checking?
Also, I think one of the connectors on the arm is broken (wiper blade held on with cable tie). Is it an easy fix or a brand new arm?
I'm not sure how broken as car is in Kenya and mum doesn't know what to look for, so if clips are cheap and easy to fix might as well send them anyway. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #687829 11th Mar 2024 10:38pm
mjdronfield
I converted to aero wipers over 10 years ago.
Much better….
https://www.ebay.co.uk/itm/234655773605
You remove and get rid of the plastic bit from your wiper arm and fit the new ones these come with…. Or save them if you want to go back to standard… but I never wanted to.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #687832 11th Mar 2024 11:26pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Replacement clips are less than £5 from Ali-Express if you are prepared to wait
https://www.aliexpress.com/item/4000491620...18026uwfbn
Although is cheaper to replace with the Aeroblades above - which I will be doing next time! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #687842 12th Mar 2024 9:32am
DrRob
Yep. Aero blades here too.
Remove all the brittle plastic off the ends of the arms and fit the aeros.
I use HQ ones off ebay Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #687852 12th Mar 2024 11:11am
shalz
Perfect thanks. I'll go with that. Any videos I can send for them to do it properly (they'll use force and break if if they don't get it)
Also, any recommendations for rear wiper? May as well get it done as well. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #687892 12th Mar 2024 7:23pm
dhallworth
I had HQ ones on my old car and hated them. After a few weeks they were useless so I reverted to Bosch 808’s and have never looked back. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #687922 12th Mar 2024 11:38pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I converted to Aero's years ago, much better cleaning, quieter, no flutter at speed, no problems at all, would never go back to the standard ones, cost less than standard as well, £20 for 2 fronts and a rear, although the rear is a standard one, not aero. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #687926 12th Mar 2024 11:48pm
dingg1
Bosch 808s for me
Post #687941 13th Mar 2024 8:49am
PeteT80
Bosch 808’s on mine.
Post #687948 13th Mar 2024 9:14am
shalz
Will try the HQ aeros and see if someone can get them on there.
Gone with the bosch oem fit rear given no hq equivalent.
Thanks all.
If anyone has idiot proof instructions for swapping to aeros, please do send. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #687979 13th Mar 2024 12:54pm
AndyRoo
Hi, I got my last set from here: https://www.ebay.co.uk/itm/360919244512
Basic instructions are adequate, it's not rocket science, but you need to remove the plastic elements from the wiper arm to enable these blades to fit.
I can't vouch for other Aero blades, I would imagine they're all similar.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #687986 13th Mar 2024 2:09pm
shalz
Thanks for this. I've rechecked your link and the ones I bought (HQ) and realised I'm over-complicating it.
Simply unplug the little plastic fittings, and slide the new ones in... now to wait for someone to still break something! MY11 Vogue 4.4 TDV8 - "African Queen"
Post #688000 13th Mar 2024 4:34pm
