![]() | Home > Technical (L405) > Battery charge life |
| jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 747
If you have access to the LR Remote app one of the options is to put the car in low power mode for a set date which would protect the battery from discharging but I don't know how old your battery is or if it has a history of problems, If its in good condition and you can use the low power mode you should be fine.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
if you have a breakdown cover then dont worry about it ...also i believe most airport parking sites have someone who will jump start you.. ... - .- -.
| GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 242
Many thanks 2013 SDV8 4.4 SE Luxor.
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Personally, I'd get a Noco GB50 and shove it in the spare wheel well fully charged. That way, if you ever need a jump start, there's 0 inconvenience. 2015 Range Rover Autobiography 4.4 SDV8 |
