![]() | Home > Maintenance & Mods (L322) > a Wheel alignment and what to do L322 |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 190 ![]() ![]() ![]() |
I have a good Autel unit that can calibrate so another great suggestion. even though she looks even its no harm in checking.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3326 ![]() ![]() ![]() |
493mm front and 483 rear 2012 TDV8 Vogue (L322) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
To clarify - it’s the car that goes into tight tolerance mode. John
Ah ok, never heard of that before Weegie, I have heard of different settings on the alignment machines. I dont have an IID tool yet as its just too expensive here compared to the UK so will have to leave that option I guess
The alignment people should have the capability. John
Weegie
Some have the capability via OBD. You would need to check with whoever you go to. It's been suggested that you don't need to go into tight tolerance mode but tight tolerance is what is stated to be necessary for accuracy. John
Tyre alignment specialists are unlikley to have the software to put the car into tight tolerance mode. Tight tolerance mode continualy adjusts the height at each corner to mm accuracy where as the standard setup just adjusts > +/-10mm. It's unlikley normal tolerance will have any adverse effect on the overal alignment esp when bushes and joints have age related wear. The most important thing is to get a 4 wheel alignment whatever system. An out of spec rear thrust angle will cause an off centre steering wheel if just the fronts are just adjusted for toe and the steering wheel locked at 12 o'clock. It's also highly unlikley any wheel alignment woud have been done without a steering lock fitted. 2012 TDV8 Vogue (L322) |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 690 ![]() ![]() ![]() |
Hi, you shouldn't have any issue with doing an alignment on part worn tyres, I have it done as part of a major service regardless of the tyres life as long as I can remember.
Andy
As you have a collection of cars and there are limited resources in your imediate area you can do your own wheel alignments if you are handy at making a few tools and have a flat concrete surface to put your vehicle on. Have a search on Youtube. 2012 TDV8 Vogue (L322) |
Hi Jaydee
