Home > Maintenance & Mods (L322) > Squealy brakes after removing calliper counterweights |
ByronBlay Member Since: 13 Mar 2024 Location: Wilsons Creek Posts: 1 |
Hi
13th Mar 2024 8:25pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 387 |
You could try copper grease on all the metal to metal contact surfaced and the pad backs.
13th Mar 2024 10:53pm |
Hi, I stand corrected, every day is a school day.
14th Mar 2024 10:38am |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 49 |
The counterweights are for noise reduction/vibration. And yes please do not put cooper grease any ware near the braking system. L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
14th Mar 2024 11:27am |
Marcus76 Member Since: 03 Jul 2022 Location: Baden Württemberg Posts: 5 |
Hello,
14th Mar 2024 11:45am |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 66 |
Excuse my ignorance, but what do you count as a 'modern' braking system, and what is the issue with using copper grease on them?
14th Mar 2024 3:03pm |
Hello,
14th Mar 2024 3:20pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
Copper grease should not be used on aluminium as it will set up electrolysis and corrode the aluminium, it is OK if you have steel callipers but shouldn't be anywhere near aluminium.
14th Mar 2024 3:24pm |
That's very interesting and good to know - thanks.
14th Mar 2024 3:27pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 124 |
I have been given conflicting opinions stating that it should no longer be necessary to grease the backs of the pads anymore? But surely that would depend on the quality of the pad in question. Also is using something like Ceratec more suitable to use for both the pads and retaining pins to help prevent the retaining pins from seizing in the calliper or do you still use copper grease for the pins/bolts? |
14th Mar 2024 5:14pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1127 |
I use this.
14th Mar 2024 5:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2761 |
The issue with any form of grease these days is that the common use of pressure washers which are very good at removing built up brake dust on calipers can dislodge it and move it onto the friction surfaces. The only place for grease is on encapsulated sliding pins and then it's important to use the right amount and the right type. 2012 TDV8 Vogue (L322) |
15th Mar 2024 9:29am |
Hi ReggieMac New modern brake pads don't need grease on the back plate of the pad or the piston of the caliper. They now come with noise reducing shims, A lot of RandD goes into brakes now a day to stop NVH. If you apply grease on the back of the pads the shim cant do its job. The only place "Brake grease" is to be used is on the abutment point of the pad. Copper grease is not suitable for the brake environment as it is very susceptible to an electrochemical reaction known as galvanic corrosion when it comes into contact with a dissimilar metal in the presence of an electrolyte, even salty water will do. The example of this reaction is most commonly seen as the white chalky powder on the back of the alloy wheels. Copper Grease has poor lubricating properties. It is in fact an anti-seize compound. Why not grease on the caliper piston? Grease is oil based and will degrade any rubber it comes into contact with ie Caliaper piston dust cover and piston seals. Hope this help L322 TDV8 2011 Autobiography Working for an OE aftermarket car parts suppler |
15th Mar 2024 9:32am |
There is specific piston seal grease that won't react with the rubber or more importantly the brake fluid. 2012 TDV8 Vogue (L322) |
15th Mar 2024 10:04am |
