Home > Technical (L322) > Is it worth doing an egr deleted at 100k+? |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 154 |
Yes, mine has for the last 3 years. |
19th Feb 2024 2:17pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Im not sure the EGR is part of the MOT is it? |
13th Mar 2024 12:03am |
And a 3.6 doesn't have a DPF in the UK market... |
Benjerbustmills Member Since: 24 Mar 2021 Location: Thornbury , Bristol Posts: 29 |
IF the EGR is seen to be blanked or interfered with, the vehicle will fail the MOT.
13th Mar 2024 10:03am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
The EGR valve is kept closed during a regen to ensure that all the fuel-laden exhaust goes to the catalytic converter to be burnt rather than be returned to the combustion chamber where it would be burnt thus depriving the catalytic converter of fuel. |
13th Mar 2024 11:05am |
If the EGR is blanked off it is effectively closed…. Permanently.
13th Mar 2024 2:10pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 202 |
Yes- I did mine at 180k and she’s clicked past the 200k with no probs, definitely runs nicely and doesn’t smoke so I’d recommend it. 2007 TDV8 Vogue SE
14th Mar 2024 8:18pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2731 |
Is this what the tuner told you? 2012 TDV8 Vogue (L322) |
15th Mar 2024 10:50am |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 161 |
I have to admit I am 100% ignorant on EGR valves as I dont think I have ever had one give me trouble so may I ask a a few stupid questions?
15th Mar 2024 11:02am |
On the 4.4 the part is expensive and difficult to get to but also very reliable so for most peolple it's still working fine at huge milages. 2012 TDV8 Vogue (L322) |
15th Mar 2024 11:28am |
Technically you could replace the EGR’s. But, it’s a pig of a job, and they are not cheap.
15th Mar 2024 12:34pm |
There is only one EGR valve on the 4.4. 2012 TDV8 Vogue (L322) |
15th Mar 2024 12:43pm |
This is why I love this forum, the wealth of knowledge is unprecedented. I'll keep filling my 4.4 with dipetane and good fuel and someday Ill do a turbo clean with Revive turbo cleaner and after that drive hard and fast from time to time I guess! Current yokes
15th Mar 2024 5:09pm |
