Home > Technical (L322) > Detachable Tow bar
Mine turns about an inch with or without key.....
Post #68817 16th Jun 2011 5:35pm
Googsy
I have one on mine but lost the key so cant check ! On the Disco 3 I had it always took a bit of force and wiggling of the key to remove the Towbar there was never any logic to it . I suggest you put it back on the car and try a bit of jiggling the key and turning the knob . Hope that helps. Rolling Eyes
Post #68822 16th Jun 2011 5:41pm
Mine twists a bit with or without key but will not pull out more than a few mills so the hook will not drop out Evil or Very Mad
Post #68824 16th Jun 2011 5:43pm
I had two keys and was using wrong one.... Embarassed
Key turns 180 degrees then knob pulls out easily and turns clockwise and the hook just falls out.
I then removed armature after buying large enough sockets to do the job!
Finally sprayed up the underparts in Black Silk and it all looks like new Very Happy
Post #69029 17th Jun 2011 4:26pm
result... Thumbs Up
Post #69030 17th Jun 2011 4:30pm
