![]() | Home > Technical (L322) > Gearbox / non starting issue (Solved) |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
You have the GM 5L40-E transmission, so the inhibitor/xyz switch is inside the transmission.
rik__ Member Since: 12 Mar 2024 Location: UK Posts: 27 ![]() ![]() ![]() |
The cable i will check, other than that i guess ill have to call someone opening the gearbox might be a bit beyond me
Checked with the cable disconnected, still nothing on the dash cycled thought all the movement on the lever still same |
Would have been nice if it was just a cable adjustment issue. Anyway, you need to get the switch continuity tested next, which is probably easiest to check at the ECU end rather than from underneath the vehicle at the 20-pin connector.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Stupid reply coming…….would you not try and ‘un sync’ the remote locking & see if it starts? In other words, go back to where you first started? Just a thought. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 200 ![]() ![]() ![]() |
if issue is with inhibitor you can just put +12v to correct pins in the socket and you should see N and starter should be unlocked. |
So if i check the orange wire for 12v
If you disconnect the C1835 connector at the ECU and check continuity with a multimeter you should find that in Park there is continuity of the wiring (not the ECU pins!) between pins 1, 2, 14 & 17 but no continuity with pins 15 & 16
Just checking that you're definitely testing at the transmission ECU (in the E-box) and not the transfer box ECU (behind the battery)? Phil |
you were 100% correct i was checking the wrong one, pulled the cover off and found the right one (always thought it was an airbox) Tested the switch and it does work cycling through shows continuity so issue has to be somewhere else? i wonder if the instrument cluster reports the gearing to the immobilizer and not the gearbox. I was showing 2 unknown errors on the instrument cluster when i scanned it (i assumed it was the 2 lights being bad)
Fuse Number 5 , soon as i replaced car fired straight up, i think its labeled diagnostics. one victory won |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1007 ![]() ![]() ![]() |
