![]() | Home > In Car Electronics (L322) > DAB no signal |
bastion Member Since: 17 Oct 2018 Location: uk Posts: 30 ![]() |
The Dab in my car has gone foggy to say the least, is the weather???? |
Dazzab1972 Member Since: 13 Dec 2018 Location: Orpington Posts: 9 ![]() ![]() ![]() |
I have the same problem, just stop working?
mrtomyard Member Since: 04 Apr 2022 Location: Lincolnshire Posts: 12 ![]() ![]() ![]() |
I replaced my DAB module today, DAB back working perfectly! I did have fault codes stored for no communication with DAB module so worth a plug in 2011 Vogue 4.4 TDV8
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Can you say where your DAB module was found and identify part number etc. please. I did look for stations during a search last year on my 2012 Westminster but found nothing. Had the car for 7 years but may have never worked although has the right selection buttons needed?
So part number is LR019261 and it’s located very low behind the left hand removable side panel in the boot, did the job with basic tools and a glass of wine on the go on the driveway, easy job! 2011 Vogue 4.4 TDV8
Many thanks Mr Tom, I'll have a look there. |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
I have this No DAB issue too, but also have a crackly phone signal and weak FM signal which gets worse when the heated rear window is on. Can anyone recommend a fix for this please? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Replaced the DAB module in the boot, all good now 👍🏻 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Strawman Member Since: 13 Aug 2023 Location: Scotland Posts: 2 ![]() ![]() ![]() |
No DAB radio check this out from about 5:50 worked for me on my 2011 4.4 same problem worth checking as its cheap.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 268 ![]() ![]() ![]() |
You can upgrade the DAB to later model DAB+ using either of these
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
those bits do not include the required upgraded DAB+ module.... ... - .- -.
Correct - however there is part number in one of the links for the DAB+ module and there’s plenty on eBay and at breakers. |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I have one from L494. Same part number listed.
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 86 ![]() ![]() ![]() |
would be interested if anyone has got the DAB+ upgrades to work, have seen a load of previous threads where one person said they had and then no one else has been able to replicate it.
