Home > For Sale & Wanted > towbar and armature
Page 2 of 3 <123>
bozmandb9 wrote:
I'll take it! Don't need the armature really, but will take it anyway, I can pick up! I'll be in touch via pm
no pm yet david..
Post #68838 16th Jun 2011 6:17pm
OK thanks, my key will not turn at all?
Tried WD40 but no luck yet.
Post #68844 16th Jun 2011 6:27pm
is it the correct key gary..
Post #68849 16th Jun 2011 6:35pm
Its one owner car so I think it must be why would the owner of had any other?
Gary
Post #68853 16th Jun 2011 6:43pm
i only thought because you go through loads of cars that maybe the keys got mixed up...
Post #68861 16th Jun 2011 7:16pm
Good point but these were sent by seller to me in envelope this morning so I know they "SHOULD" be the right ones.... Big Cry
Post #68875 16th Jun 2011 8:04pm
the bit 'sent by seller' makes me wonder if they are the correct keys...
Post #68878 16th Jun 2011 8:08pm
@bozmandb9, david there's a pm for you..
Post #69194 18th Jun 2011 9:34pm
Scarey you were right I was trying the wrong key. Seller gave me two I thought they were the same but they were not...... Thumbs Up
Post #69212 19th Jun 2011 9:35am
at least its now sorted..mine wouldn't seperate until ample loads of wd40 sorted it..
Post #69233 19th Jun 2011 1:01pm
AMD
I took delivery of the armature a few weeks ago and just got it out of the box this morning to see how it fitted, it seems very simple enough, but......it's heavy, the bolts are big and will need a bit of leverage to undo them etc. I'm no mechanic so I guess my pair of tweezers and toffee hammer won't do the job. Is it worth getting a garage to do it? LR want 2 hours labour, that's over £200 for fitting a chunck of metal...no technical experience and qualifications required....or buy a decent socket set and torque wrench?
Has anyone tackled the job? Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #69241 19th Jun 2011 1:49pm
depends how competent mechanic you are..i gather you would have to remove the bumper first then ,with help, offer up the armature and bolt on..
Post #69242 19th Jun 2011 1:59pm
I had my towbar off a couple of weeks ago, simple enough job.
You need to remove the back bumper and drop the rear exhaust. To drop the exhaust just remove the rubber connectors and don't forget to remove the one half way towards the front of the vehicle to allow it to drop without damaging.
Post #69244 19th Jun 2011 2:24pm
ric355
I did mine yesterday. The bolts holding the bumper support on are tight so you'll need a longish bar to get good leverage, or an air tool. The rearmost mount bolts are recessed so you'll need an extension bar as well. To manage the weight of the armature, just use a trolley jack in the middle to lift it into place. This makes positioning it very easy and a one man job. I also supported the exhaust with a small bottle jack and wooden block to stop it dropping down and stressing joints further back.
Post #69249 19th Jun 2011 3:22pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I needed an air gun to get the four bolts undone but apart from that the whole job is very much DIY Thumbs Up
Dealer wants 2 hours but I would allow 3 for DIY just in case Wink
Andy 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #69253 19th Jun 2011 5:42pm
Page 2 of 3 <123>
