Home > Maintenance & Mods (L322) > Oil mist debris on radiator
olavfo
Norway 2010 Range Rover Autobiography TDV8 Buckingham Blue
Hi all,
2009 3.6 TDV8 @ 217 000 km / 135 000 miles
I was refilling the windshield washer fluid and noticed that each side of the radiator was wet, and it's oil. Are the hoses just above the wet areas the outlets of the charge air cooler? Am I wrong to think there shouldn't be any oil there..?
I was hoping one of you experts might explain what might be going on here, and what I should do about this.
Best regards,
Olav
Post #688440 19th Mar 2024 6:57pm
JayGee
It’s common on the 3.6 for the hoses from intercooler to intakes to split so get these replaced ASAP as leaking intake charge can cause the turbo’s to overspin as they try to compensate for the loss of pressure. 2012 TDV8 Vogue (L322)
Post #688459 19th Mar 2024 9:26pm
olavfo
Thank you, I will definitely check them for a leak and order new ones. But, why the oil? Shouldn't the intake charge be clean as a whistle?
Post #688465 19th Mar 2024 9:57pm
JayGee
All turbo cars leak some oil vapour from the compressor seals. 2012 TDV8 Vogue (L322)
Post #688483 20th Mar 2024 8:48am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I just changed the intercooler hoses on my FF 3.6 TDV8, the old ones did have a smear of oil on the inside, as JayGee says, some oil is nothing unusual after quite a few years of use.
Post #688501 20th Mar 2024 11:36am
