Home > Maintenance & Mods (L322) > High speed juddering
Rudyard1
I have searched the forums for an answer but only seem to draw blanks. I have an issue at speeds above 60/70mph when turning ever so slightly. Those high speed curves on a motorway for example.
I have recently had handbrake module replaced, tracking completed afterwards (as rear subframe was dropped to access handbrake, although the rear suspension didnt need alignment doing as this was fine - only the front was adjusted).
Does anybody have any idea what could be causing this high speed slight turning judder through the steering wheel??? 2007 Range Rover Vogue 3.6 TDV8
Post #688603 21st Mar 2024 2:03pm
kevinp
I have a similar issue because I need to get my front wheels rebalanced. Very slight juddering going straight ahead which gets slightly worse in the conditions you are having. Worth a try.
Post #688607 21st Mar 2024 2:22pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Sounds like the front arms are on their way out?
Post #688668 21st Mar 2024 10:55pm
Rudyard1
Tb10 - spot on. OSF lower arm shot. Replaced and what a difference! 2007 Range Rover Vogue 3.6 TDV8
Post #690184 7th Apr 2024 8:28pm
tb10
@Rudyard1: excellent. Appreciate the feedback and glad to have helped. Thumbs Up Oddly, I have a set in my car atm ready to fit! Laughing
Post #690196 7th Apr 2024 11:14pm
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Out of interest, it would be useful to know what it cost to have the arm replaced? Could you kindly share. Thank you.
Post #690426 11th Apr 2024 6:43pm
Rudyard1
I bought the originals from Advanced Factors and replaced them myself. The OSF failed so I have sent this back as they are Lemforder parts and have a 3 year warranty. I bought a replacement lemforder from Eurocarparts and just swapped it out and have sent the knackered one back to AF.
£70 from ECP.
If you attempt it yourself I suggest MAP gas and a flexible heat shield (so that when you cook the bastard thing you don’t inadvertently destroy the upper arm ball joint! 2007 Range Rover Vogue 3.6 TDV8
Post #690428 11th Apr 2024 7:03pm
