Home > Technical (L405) > Holes in boot behind numberplate - mystery
Henry12345
Just been replacing my numberplate on my new but old 2016 Auto. Found dreaded gaffer tape.
Underneath the gaffer tape are all these holes (clearly from the factory as opposed to being cut in).
My question is: should the holes be plugged and does it matter if water gets in?'
Pics to show.
Post #688644 21st Mar 2024 7:06pm
Vogue
They are all like that, and they are sealed from the factory with waterproof tape - the trouble is when anybody removes a stick on plate it pulls the tape off as well - the result being that most people just stick gaffa tape over the hole 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #688648 21st Mar 2024 7:36pm
Gremlin500
………. V6 Vogue - “Less is More” - less to go wrong!
Post #688674 21st Mar 2024 11:58pm
Vogue
Petrol is cheaper Laughing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #688675 22nd Mar 2024 12:07am
johnboyairey
Didn’t I read so where that generally, cars have vents here, to stop your ear drums popping when door slammed? Also allows low pressure behind moving car to drag out foul air to stop you dieing of asphyxi-fart-ation.
Post #688676 22nd Mar 2024 12:18am
fisha
Not sure about the tailgate, but there are often inner bodywork vents in the rear qtr panels behind the light clusters air.
I always figured that was to allow air out which the blowers at the front of the car had blown into the cabin. I suppose they would also suppress pressure waves. V8 or else ...
Post #688677 22nd Mar 2024 1:38am
Weegie
Gremlin500 wrote:
Just in case anyone doesn’t already know amongst you very knowledgable lot on here, the best stuff to get rid of all that old adhesive is lighter fluid, -works like a charm with an old credit card scraper! Thumbs Up
Embarassed I bet everyone knew that already! Laughing Embarassed Embarassed Embarassed
So does WD40 Cool John
GAP iiD BT-Sold
Post #688681 22nd Mar 2024 8:32am
Gremlin500
Post #688702 22nd Mar 2024 12:04pm
i wonder what cables/wires are accessible via those holes.. ... - .- -.
Post #688706 22nd Mar 2024 12:18pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Hmm, that reminds me of the "secret" L322 access to the tailgate latch...
Post #688715 22nd Mar 2024 1:14pm
adara
Those are behind the tail lights.
Post #688716 22nd Mar 2024 1:15pm
TST717
I like that tip .... there was me using up my Autoglym tar remover on it ....!
Lighter fluid it is from now on ..!
Post #688751 23rd Mar 2024 6:54am
garyRR
The holes are there from factory. The insert needed is about £1.60 for a pair. 2015 Range Rover Autobiography 4.4 SDV8
Post #688764 23rd Mar 2024 9:14am
Henry12345
Where can you get them from?
Post #688813 23rd Mar 2024 4:23pm
wholesealer Mr. Green ... - .- -.
Post #688825 23rd Mar 2024 8:05pm
