![]() | Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 418 ![]() ![]() ![]() |
Anyone know why these things cost like £150 a pop?
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 95 ![]() ![]() ![]() |
I would just bite the bullet and do it properly. Imagine where your car will be in a few years time if you just bodge all of the jobs to save a buck. I don't think any of us here bought these cars thinking they are cheep to fix or run. |
i do mean for the rears, so id still need a dust shield no? Its actually a sport |
tbh i think am leaning that way anyways. anyone know if i can replace the CV joint in situ atleast? Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
As CASS stated you need the dust shield because it retains the hand brake pins. But you also need the shields to stop all the road grim from gumming up the brakes. Not having these would leave to more money having to be spent in repair work because of caused problems than that of the price of new shields. 2010 RR Autobiography 5.0 SC
Front or rear? 2010 RR Autobiography 5.0 SC
rear.
You will need to unbolt the rear knuckle joints and so while at it you might as well replace the bushes at the same time. It's a more time consuming job than anything. Genuine bushes are only about £25 each. 2010 RR Autobiography 5.0 SC
oh am going for the entire rear end rebuild. unfortunately the car is a rust bucket so
I always think, as long as you have sound chassis, anything else that goes rusty or faulty can just simply be unbolted and replaced.
Success, the shaft is out the knuckle
That's the awkward one. To replace the hand brake cable, it goes back to the module mounted on top of the rear subframe and I think that needs to be lowered to get to it. So however you look at it, it's a sod of a job and would need to be done on a ramp. 2010 RR Autobiography 5.0 SC
no chance of a ramp here, ive got the cable out, but wrecked the bit that screws it into the knuckle.
I've started to track this headache of a jobo.
