![]() | Home > Technical (L405) > B1D55-Antenna 2 circuit |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1494 ![]() ![]() |
I thought about the curry connection, but because the keyed locating tab shapes and positions on the connectors are unique to the colour it was definitely the TV brown type.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1377 ![]() ![]() |
Well done and great feedback
Bisto36 Member Since: 07 Mar 2024 Location: Cambridgeshire Posts: 5 ![]() ![]() ![]() |
Hi , great info been following you post as I have the exact same problem , B1D55 -11 stored , have checked my unit under the spoiler , no corrosion at all and all connection look ok , so will be going for a new module like you did
Hi Bisto,
Fisha , thanks for your reply , I held back coming back to you as I wanted to try a couple of options first , but still doesn't work .
Do you have any additional equipment in the car like dashcams ? They are known to cause notable interference of DAB / radio signals in a car. When I first set out trying to fix the issue, I bought a load of ferrite cores and used them around the power cables to the dashcams. ( Whether it made a difference or not, no idea, as at that time I hadn't discovered the corrosion of the aerial amps in the spoiler. V8 or else ... |
No , I haven't.
Two TV antennas are located in each rear quarter window glass and their amplifiers are located above and below the window glass. The TV antenna in the right rear quarter glass is also used for the Fuel Fired Booster Heater (FFBH) remote control RF reception, when fitted. There are 3 TV amplifiers and 1 TV/FFBH remote control RF amplifier fitted. The antenna on the left side rear quarter window are for TV only. The upper antenna in the right side rear quarter window is for TV only, the lower antenna is for TV and FFBH RF reception. The 3 TV antenna amplifiers are functionally identical assemblies, but, have handed RF input connections to the press stud on the rear quarter window glass and steering pins. The combined TV/FFBH RF amplifier is a unique unit with 2 co-axial plugs. Maybe where the 3 TV aerial coax cables meet at the press stud? and then that connection to the Television control module in the rear has corrosion/loose/broken connections? Is it the TCM thats at fault? The audio/TV system is on the MOST bus and your fault is common to this bus, any DTC? look at the end of this thread https://www.fullfatrr.com/forum/post600356.html 2018 SE SDV8 4.4 Byron Blue |
Kot , Hi , thanks for the info , sorry for delay coming back
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87 ![]() ![]() |
I suddenly have terrible DAB reception and found this super helpful thread (thanks for posting all the detailed info!)
Discussed in this one ... except you just remove the nuts completely and the spoiler will lift off ( although with wires still attached.
Aha, thanks.
Even weirder. DAB fine this morning. Scanned the codes anyway - nothing! (Well, nothing related to the radio anyway; it is still a Range Rover after all so obviously there were some codes…) |
