Home > Maintenance & Mods (L322) > Iid please help
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Iid please help
I tried to get digital speedo with my iid tool and it did not work now have all these faults showing, please advise what to do. Everything was fine beforehand. I had the engine running and plenty of voltage. Should I try again?
Panicking right now!
Do I have to turn off and leave for a while?
 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689059 26th Mar 2024 5:56pm
withe a iidtool you can revert to the settings before any adjustments....or leave for an hour and see. ... - .- -.
Post #689060 26th Mar 2024 6:00pm
Baltic Blue
Yes you can Stan if it’s a 2011 4.4 tdV8 ?
I am just scratching my brain to try and remember how I did mine. Rolling with laughter
Cheers
Mike. Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #689061 26th Mar 2024 6:11pm
my bad mike.. Thumbs Up ... - .- -.
Post #689062 26th Mar 2024 6:13pm
Buellie
Thanks, all cleared now but no digital speedo Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689064 26th Mar 2024 6:15pm
how to from the wiki,
https://www.fullfatrr.com/forum/post645713.html#645713 ... - .- -.
Post #689067 26th Mar 2024 6:18pm
Baltic Blue
From memory it’s in the body control module BCM, something like activate 2nd speedo.
Post #689068 26th Mar 2024 6:18pm
Buellie
On holiday from work, new car, new iid tool, complete idiot, what can possibly go wrong 😂 Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689069 26th Mar 2024 6:19pm
Baltic Blue
The good thing about this forum, you can always rely on Pete Thumbs Up Thumbs Up
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #689070 26th Mar 2024 6:21pm
JayGee
Anytime you change something in the CCF it will throw a set of warnings and system failures. You just shut down, lock and unlock the car and it will be fine. You will also see the clock resets as do windows , date, etc which is anhoying. 2012 TDV8 Vogue (L322)
Post #689072 26th Mar 2024 6:55pm
Buellie
Many thanks for that info Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689075 26th Mar 2024 7:41pm
Buellie
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689076 26th Mar 2024 7:42pm
Buellie
Thanks Stan
I did read and follow that. The last bit is not so clear, do you know what I have to select for the digital speedo?
I selected second display units same as trip meter Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #689077 26th Mar 2024 7:46pm
PeteT80
Re: Iid please help
Are you not supposed to just have the ignition on to edit the CCF?
Post #689079 26th Mar 2024 8:03pm
JayGee
The GAP site has a very comprehensive FAQ in addition to the user manual where 99% of issues or questions can be resolved. Anything unusual that can't be found and emails to the team are usualy answered very quickly. 2012 TDV8 Vogue (L322)
Post #689081 26th Mar 2024 8:15pm
