Home > Maintenance & Mods (L405) > SMOKE & FUMES STILL after oil cooler changed!!…
Page 3 of 3 <123
garyRR
Just a thought - have you checked the oil feed hoses (I believe they're the turbo feeds) at the very top back of the engine block (you need to remove the plenum chamber to access, and you won't be able to see, so will have to feel or use a mirror or camera)?
The o-rings on these eventually fail and the oil works it's way down onto the bell housing where it burns off. As it's directly below the cabin air intake, it would be easy for the fumes to get in the cabin.
Quite a straightforward fix, but is done blind. 2015 Range Rover Autobiography 4.4 SDV8
Post #686316 23rd Feb 2024 9:37pm
RR2020-95
2019 Range Rover Autobiography SDV8 Carpathian Grey
Hi Jay, did you manage to sort this issue out? Ive just had my oil cooler done and changed the coolant with a new reservoir. The next day i got on the m way took it for a blast slowed down into traffic and getting loads of smoke coming into the cabin! Ive had the garage check it out again they are not sure
Post #689290 29th Mar 2024 4:15am
RR2020-95
Its coming up to about 4 weeks and Ive done 800 miles since however i is still doing the same thing 😑
Post #689292 29th Mar 2024 4:24am
CarlM93
Hi Guys. i had my oil cooler changed around 3 months ago and i am also having the same exact issues as everyone else here. im going to do some investigations myself saturday and will update if i find anything which may help
Post #694751 20th Jun 2024 11:11am
Page 3 of 3 <123
