Home > Maintenance & Mods (L322) > L322 Deployable steps - noisy gearbox
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
I had to drive through extensive floods recently and I suspect water has entered the motor/gearbox as it now has a nasty dry squeak when operating.
Is it possible to remove the motor and gearbox without the rest of the mechanism?
I read somewhere that the arm bolts can shear off from the body due to corrosion.
Thanks to anyone who knows or has done this. Forty years of progress. 1972-2012
Post #689539 31st Mar 2024 6:39pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
The motors are sealed extremely well and a sure sign of motor failure is a loud clicking noise when they operate. Chances are the brackets could do with a good clean and good dose of lubrication. I've just bought a fatty with the steps fitted, although they was very slow at first, a damn good jet wash and lots and lots of plusgas, they are working perfectly. I had my old steps fail on me on my other car and tried to dismantle the motor, virtually impossible.
Personally i don't use WD-40 and I'm not a fan of PTFE lube either. Hope this helps.
Post #689629 1st Apr 2024 5:31pm
Arbuckle
Thanks BB,
No clicking, so lots of lube on the way.
I'll check in next weekend with the results.
That's progress. I just need step ladders to get in the '72. Rolling with laughter Forty years of progress. 1972-2012
Post #689644 1st Apr 2024 8:27pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Both my motors failed due to water ingress. These were the factory ones. I have since removed my steps with a view to replacing the motors and I have welded the brackets as both had split but I havent removed the motors yet as it seems a bit of a job to get them out. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #689727 2nd Apr 2024 11:17am
Arbuckle
Fate was smiling this time.
Copious oiling and all is well.
Smile Smile Smile
Thanks for the info from 'those in the know'. Forty years of progress. 1972-2012
Post #689827 3rd Apr 2024 5:57pm
Arbuckle
Smile Smile Smile
Post #689829 3rd Apr 2024 6:22pm
