Home > Technical (L322) > Hunter alignment specs for l322
Klunk
I recently had a 4 wheel hunter alignment done.
When I looked at the paper work it showed a l405 settings…
Anyone know if they are different and if so what should the l322 be .. trying to work out if I need to take it back.
Car handling has been transformed but I don’t want uneven tire wear.
TIA
Post #689778 2nd Apr 2024 8:47pm
JayGee
The wheel alignment specs are in the workshop manual downloadable from this site's Wiki section 2012 TDV8 Vogue (L322)
Post #689794 3rd Apr 2024 8:00am
DrRob
It will be different for sure.
Take it back and educate them on an L322 vs an L405 Rolling with laughter Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #689799 3rd Apr 2024 8:20am
my L405 hunter adjustment from kwik fit was specced as a L322 because of my '05' personnel reg number..
numpty's.. Rolling Eyes ... - .- -.
Post #689800 3rd Apr 2024 9:32am
pcourtney
my TDV8 2011 L322 was Front Toe +9° Rear Toe +12°
Post #689805 3rd Apr 2024 11:55am
Klunk
Thanks all, really helpful.
I’ve been through the settings in the workshop manual.
Yep, different spec to l405. But…
My settings are all within spec for my model l322. Hilarious. Well that’s off my mind now.
Post #689808 3rd Apr 2024 1:41pm
Rudyard1
I went to kwikfit a while back for new boots and the ‘experienced’ fitter came in to the waiting room to tell me there wasn’t any adjustability on the rear. Looked on his screen and he had it set up to something like an 89 Range Rover…….
Question everything and all that…. 2007 Range Rover Vogue 3.6 TDV8
Post #689838 3rd Apr 2024 7:19pm
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
I had my alignment done and although everything was green and looking correct it veered to the right when driven, had it looked at again but this time with the engine running and it showed a different reading. Once it was tweaked it drove straight.
I really can’t drive a car that has a steering wheel at an angle - never know how taxi drivers do it! 2009 pre-facelift 3.6 TDV8.
Post #689957 4th Apr 2024 11:40pm
JayGee
With the engine running the car will have the suspension active to level itself. Idealy you would also use a workshop tool to set the suspension in tight tolerance mode preferably after doing a suspension height calibration. 2012 TDV8 Vogue (L322)
Post #689965 5th Apr 2024 6:44am
DrRob
It also needs half a tank of diesel in it and locked into Tight Tolerance Mode Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #689973 5th Apr 2024 9:24am
KitTheRam
Hopefully not a silly question but - what is tight tolerance mode and how is it in engaged? 2009 pre-facelift 3.6 TDV8.
Post #689985 5th Apr 2024 11:53am
JayGee
Continual height adjustment rather than only when it’s +/- 10mm in normal use. Needs a capable diagnostic tool such as the GAP IID 2012 TDV8 Vogue (L322)
Post #689986 5th Apr 2024 12:31pm
