![]() | Home > Maintenance & Mods (L322) > Front Light Guard fitting : How to |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
I just fitted the OE front lamp guards to my car and have to say the instructions could be better.
I also fitted a set of rear light guards tonight so I will get some pictures posted soon. Discovery 4 HSE
Front ones and rear ones done now, very easy to fit.
| shmoogle Member Since: 26 Mar 2007 Location: Mongolia (where the Mongs come from) Posts: 108
Do you not get mud and crap caught behind them Adam? How does this sit with your mentalist cleaning routine? |
That might happen I suppose, but that just gives me an excuse to clean it harder! |
| ammars27 Member Since: 22 Jul 2008 Location: Essex Posts: 9
using the templates you do not need to drill any part of the car body work at all, the mounts fit on behind the lights it took me like 2 hours to fit the all front and back but without drilling any of the cars bodywork? |
must be a different front kit to mine. The factory ones are drilled into the front of the side wings, I just saw a set on a car at a dealer up the road from work.
actually if look at it it looks like it drilled but there is a thin plate fitted to the indicators that hold the front one i only fitted a set last week |
The ones I had which are genuine version have a plastic mounting strip underneath the guard by the indicator strip. This has to be mounted by drilling 2 holes in the wing and pushing in two threaded plugs. The light guard itself is then screwed onto the mounting strip using 2 allen head screws supplied. Discovery 4 HSE
ok i guess my ones were differnt but were supplied by main dealers and i did not have to drill the body work, coz if they get bumped it damages the whole wing which is a more disaster then the light! |
Might be cos mine is a facelift version and they changed the fittings?? Discovery 4 HSE
never know? |
| ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936
Guys the thread nut is known as a rivnut and a proper tool is required to fit it properly Adhesive really is not the answer |
| pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20
I have got the light guards fitted to my FFRR i think they look excellent and they make no difference to the cleaning! |
