Home > Technical (L322) > 4.4 TDV8 pressure at pump
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Does anyone know at what pressure the the diesel pump (low pressure in the tank) pumps at please?
Trying to buy some fuel pipe and need to know what pressure rating to buy
Many Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690066 6th Apr 2024 11:14am
Baltic Blue
Have a read of the WM for fuel system pressure testing procedures, but I think 5 bar maybe the answer.
Cheers
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #690068 6th Apr 2024 11:24am
Buellie
Thanks but is that the in tank pump pressure, I thought it would be less?
If I am reading this correctly is it 0.5 bar from the in tank pump and there is a secondary pump that pumps to 5.5 bar in the wheel arch??
https://gershon.ucoz.com/LANDROVER/RANGEE/...DIEZEL.pdf Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690070 6th Apr 2024 11:30am
GraemeS
Australia
From the WSM...
The low pressure system pressure is 0.5 bar up to the secondary fuel pump and 4.5 bar from the secondary fuel pump to the high pressure fuel pump. Return pressure is less than 0.5 bar.
Post #690074 6th Apr 2024 12:17pm
Buellie
Thanks guys appreciate your help with this Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690093 6th Apr 2024 3:09pm
