![]() | Home > In Car Electronics (L322) > Invery steering wheel controls |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
Depending on what ‘mode’ you have the Invery set to you should be able to change tracks as I can. 2012 TDV8 Vogue (L322) |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 154 ![]() ![]() ![]() |
I have it set to iPhone mode Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
Try the other mode? 2012 TDV8 Vogue (L322) |
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 19 ![]() ![]() |
Interesting, I can only skip a track forward, no reverse on my Invery . How do you change the mode? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Press back twice with a gap of 1 second and it will go back a song. 2015 Range Rover Autobiography 4.4 SDV8 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
On the Invery adapter in my car, sometimes the skip back and forward buttons work, sometimes they don't. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
There is a small switch on the unit. 2012 TDV8 Vogue (L322) |
fatu Member Since: 02 Feb 2024 Location: Prague Posts: 46 ![]() ![]() ![]() |
coming from 2008 3.6 tdv8, it is annoying enough that i always use the right side buttons on the steering and get the dashboard menu activated |
found my own answer, power button is for pause basically |
