![]() | Home > In Car Electronics (L322) > Radio system wiring plugs |
rik__ Member Since: 12 Mar 2024 Location: UK Posts: 27 ![]() ![]() ![]() |
Further update, it appears to be drivers door speakers (top tweeter included), drivers back door speakers and centre dash speaker when putting balancer all the way to the left the humming stops (might be related but all the controls on the drivers door have stopped working). was looking at the loom going into the door and it appears to be secured with a 10mm nut?, does that have to be undone to get the plug out? (might need to buy a new tool for that) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
From memory, You need to take off the lash down loop chrome thing using an Allen key then you can undo the plastic nuts that are in the hole recesses in the black plastic boot floor cover…. Just an extra bit comes out, to give you complete access.
Hi mjdronfield
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 ![]() ![]() ![]() |
Correct, that bit. It’s quite easy. You can gently lift the other panel so you can slide the plastic bit out. It all comes apart really easy - I’ve just stripped the whole lot out and put it back again |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 923 ![]() ![]() ![]() |
Try to replace the SatNav CD system with a BMW MK4 DVD GPS unit ( DVD ROM Drive ) , then you can enter a UK postcode on the screen ( only the MK4 model can do this )
Thank you all for your reply, in my effort to try and sort this car I again have made it much worse, cleaned up all the electronics but think I have some of the arials in the wrong place maybe some other cables aswell sat nav on road and off road missing from radio menu and opening any door other than drivers makes a very loud buzzing (almost like an alarm) |
Ok so it turns out it was the driver side speakers again, unplugged them all and the noise has stopped, do you know if rave has a pin out for all the electrical systems in this car. think im going to have to look and test everything |
Anyone seen the sat nav (on road and off) just disappear from the menu, i double checked the cd player has power and it reads and ejects the disc no problem |
well some good news ive found were the water is coming in
