![]() | Home > Technical (L322) > Removing Headrests? Anyone know how? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
only four bolts holding the seat in place , and very easy to get the seat out..its also an opportunity to clean under the seat properly..
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
If you have the seats pre the inset headrests at the top of the chair, then put the headrest up at the top and give each shaft a hard tap upwards to release the pop in holders, but if you are fitting a rear screen set then you'll need to get in by removing the lower leater cover and the fun filled plastic filler to allow you to route the cables correctly on re-assembly
Or maybe try this remove the rear panel behind the seat.
