Home > Technical (L322) > Sounds from the wheel
przemi
Poland 2010 Range Rover Supercharged 5.0 SC V8 Santorini Black
hi all, since I have the car I hear a strange sound from the wheel area and stops only after the engine ist turned off. Does anybody have any idea?
Post #690254 8th Apr 2024 5:15pm
RRPhil
"....and stops only after the engine is turned off"
Are you saying that the noise is still present when the vehicle is stationary?
Phil
Post #690259 8th Apr 2024 6:14pm
przemi
Now that you ask…strange - it is actually most noticeable when the car is standing (e.g. at traffic lights), cause while driving above 30 mph it is covered by other driving noise.
Post #690269 8th Apr 2024 7:31pm
dhallworth
If it’s happening when the car is stationary then it’s not the transfer box that’s causing it.
Does the noise change if you put the car into neutral?
My guess is it’s an idler pulley or something that’s got wet and muddy whilst off reading. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #690276 8th Apr 2024 10:24pm
przemi
ok, I see your point regarding the transfer case But it would rather get louder in the motorbay if it would be one of the pulley or the alternator, wouldn´t it?
Post #690285 9th Apr 2024 8:07am
CS
Have you tried moving between high and low ratio a few times in case something that did not disengage fully the first time then does so? Only Range Rovers since 1988
Post #690309 9th Apr 2024 2:38pm
przemi
Thanks, it stopped on its own
Post #690314 9th Apr 2024 3:04pm
