![]() | Home > Maintenance & Mods (L405) > Do you *need* to change the oil filter ? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
I'll play |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I'll play back with very rough numbers:
With those figures, I'd agree.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2734 ![]() ![]() |
The filter won't release any oil just because the sump is drained but releasing the filter cap a few screw-turns will allow the oil to drain, but then don't forget to tighten it again later. However by not releasing the filter, oil can't drain from the bearings which whilst would drain a little more oil, would keep more oil in the galleries on start-up. Oil pressure takes longer to build after an oil change than on normal start-ups, as indicated by the rattle starting after an oil and filter change. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
So in that case for this oil change it might be better not to change the filter? overfinch modified |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 254 ![]() ![]() ![]() |
New engine $25,000
