![]() | Home > Maintenance & Mods (L405) > some sort of electric problem |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
Search under "wheel arch earth" there is a thread 'ABS module' which has useful pictures and commentary. Also try charging the battery and see if that helps and check if it will hold charge. Only Range Rovers since 1988 |
| planetkiller405 Member Since: 25 Oct 2023 Location: Ipswich Posts: 19
Thank you for this I’ll get it on charge and see what happens |
Checked earthing points under drivers wheel arch all good, cleaned and sanded etc.
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1525
Have you tried this
Thank you for suggestion. I believe this doc is for the L322 not the L405. There is no tab like that in the L405. Sadly, as it would be a great thing to have!
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
I think that is for the L322 not the L405... Maybe it has something similar... Pete
Sadly the L405 boot can only be opened with power available. Unless someone knows another way but I can’t find any info - it all says connect battery or another car to poles under bonnet |
Sorry my error, try this.
thank you again - however I have no power at all to the tailgate. So there is no stuck actuator or stretched cable etc! And no actuator noise in the catch (like in the video). There's nothing, along with no ability for the dash to initialise - it tries to initialise - the LR logo comes up, goes away, comes up, goes away - like something's stopping it from firing up.
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 704
Hi, It's kind of off the wall but would applying 12v directly to the output of the fuse (fuse removed) for the central locking give you enough to get it open.
thanks yes, interesting thought! I have no idea if that would work but it might. Interestingly, the unlock button on the door panel clicks all the doors - but it seems theres no power to the actuator - so I'd look for the fuse for the rear tailgate and try 12v on that maybe - but to be honest its going past my skill level a bit!
Hi, yes, if the bus is being dragged down by something it'll stop the unlock signal reaching the tailgate. Pretty much how a Ghost imobiliser works but on the starter circuit.
Thank you I’ll have a look. It seems to be quite complicated but I’ll have a poke around.
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
To be honest I wouldn't have gone as far as you have with Extended warranty in your back pocket.
