Home > Technical (L405) > Coolant loss, help required
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I have been losing coolant at approx half a litre a day regardless of being used or standing so assumed a leak somewhere, parked it on a dry area (difficult to find in Scotland at the moment) and it is leaking from the drivers side just ahead of the wheel, any ideas chaps/chapesses Thumbs Up 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #690753 16th Apr 2024 5:18pm
kevinp
There is a second radiator under the arch cover. I remember someone having a leaky hose on it. Thumbs Up
Post #690754 16th Apr 2024 5:29pm
Rosco
Thanks kevinp, will have a look Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #690758 16th Apr 2024 6:07pm
Rosco
Post #690759 16th Apr 2024 6:44pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
That 2nd radiator is one of the intercoolers surely?
Is it actually leaking there?, or just dripping from the edge of the under-tray? I would take the tray off and have a look to see where it's actually coming from.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #690760 16th Apr 2024 7:00pm
Dolphinboy
on my L322 it was suspected a EGR leak was causing a slow coolant leak.
Post #690762 16th Apr 2024 7:19pm
Re: Coolant loss, help required
Front or back wheel my friend..?? Pete
Post #690763 16th Apr 2024 7:28pm
Rosco
Front wheel Pete Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #690778 17th Apr 2024 6:12am
OK, there is a common leak for in front of the rear wheel...!! Pete
Post #690801 17th Apr 2024 10:36pm
Dolphinboy
Is it definitely coolant and not power steering fluid? if so, could it be this?
https://www.fullfatrr.com/forum/topic69415.html
Post #690884 19th Apr 2024 10:24am
kevinp
Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temperatures under
arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in
the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The
auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the
main engine thermostat."
Just for info on possible leak.
Post #690893 19th Apr 2024 11:30am
