Home > Technical (L322) > 4.4 TDV8 - Restricted performance issue on long road
Glaruss
Bulgaria
Hi all,
As the title says, I am experiencing trouble with the "Restricted performance" message while driving outside of town.
While I am driving in the city there is no issue, even when I am accelerating on the boulevards activating the second turbo.
The message appears while I am driving on the motorway, after a while, with constant speed of around 120km/h, often on a hilly part.
So far I have checked the pipes and the manifold with smoke test, there is no problem with them...everything seems to be okay. The mechanical parts of the turbos are also fine but I am wondering about the valve or MAF/MAP sensors.
Any suggestions what may be the issue?
Post #691109 22nd Apr 2024 6:25pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Check the MAP sensor is not blocked with black gunge.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #691112 22nd Apr 2024 8:15pm
Glaruss
Bulgaria
Hi Chris,
Thank you for the suggestion! Today I decide to check the MAP sensor and it was covered In black gulch. I cleaned it but still haven't tried the car after tthat. Could the dirty MAP causing this issue?
Post #691113 22nd Apr 2024 8:23pm
ChrisJC
There are about 4 little holes in the bottom of the sensor. Did you clear them out?
P38 - 4.6V8 HSE
Post #691114 22nd Apr 2024 8:26pm
Glaruss
Bulgaria
Didn't saw any holes Very Happy , I guess i should take it our and clean it again! Can you suggest a good way to clean it? With spray or to poke it with something 😂
Post #691117 22nd Apr 2024 8:33pm
ChrisJC
I poked with a small piece of wire. Just to clear the holes.
P38 - 4.6V8 HSE
Post #691118 22nd Apr 2024 8:37pm
Glaruss
Bulgaria
Thank you for the advice Chris! Will tried it tomorrow.
Post #691119 22nd Apr 2024 8:40pm
ChrisJC
P38 - 4.6V8 HSE
Post #691121 22nd Apr 2024 8:42pm
JayGee
Unlikley to be the MAP sensor given the symptoms. Usual culprit for these errors when going into the 2nd turbo stage is the CSOV valve that controls the airflow to the 2nd turbo located lower right front nr the radiator esp if it's the earlier version. Plenty of info on here about it if you input CSOV into the search function. 2012 TDV8 Vogue (L322)
Post #691130 23rd Apr 2024 8:30am
Glaruss
Bulgaria
Hi Jay,
I was wondering, could it be CSOV if the message appears even when i have not activeted the second turbo and was just driving bellow 2500 rpm? For example driving on the motorway with around 1500-2000 rpm - 110-120km/h
Post #691133 23rd Apr 2024 9:05am
JayGee
Sorry I misread your post and thought it was only over 2400rpm Embarassed . Worth cleaning the MAP sensor anyway but avoid poking anything in it and just use brake cleaner spray. Proper diagniosis will need a scan from something like a GAP IID tool to get some error codes. 2012 TDV8 Vogue (L322)
Post #691135 23rd Apr 2024 9:16am
Glaruss
Bulgaria
Okay.
I cleared really good the MAP sensor and tested the car. Still the same - when i try to accelarate slowly going uphill on the motorway with aroun 1700-2000 rpm - the car goes in limp mode : (
Post #691142 23rd Apr 2024 12:36pm
JayGee
Get a diagnostic scan and see what faults are logged in the ECU. 2012 TDV8 Vogue (L322)
Post #691146 23rd Apr 2024 1:01pm
Fox889
Glaruss wrote:
Okay.
Did you remember to clean the hole the MAP sensor sits in? Mine went into limp mode on the motorway at 65mph, turned out to be a blocked sensor & also the hole was full of crap! 🫣 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #691183 24th Apr 2024 7:30am
Fox889
1973 Honda CB250 K4
Post #691198 24th Apr 2024 1:56pm
