![]() | Home > Maintenance & Mods (L322) > Gearbox Megaflush by Bodsy |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
In practice, one of these boxes can manage 150,000 miles or more on the genuine fluid.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I think I read that ZF recommended 10 years if I remember right.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
Does a 'megaflush' use the genuine ZF fluid? The sump has a filter and magnet and can develop leaks (mine did) to the seal with age as the rubber hardens so it' a good idea to have this replaced with a genuine one. Not sure if this is ofered as an option during a megaflush? The service kit includes a new sump and enough oil to change about 1/2 the oil which IMO is enough to prolong / preserve the gearbox. The idea of 'flushing' certainly sounds good but I'm yet to be convinced it offers a genuinley better outcome than a 'service' using genuine oil and a sump. 2012 TDV8 Vogue (L322) |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
The mega flush is a process, so I guess you could use whatever fluid you want.....
A megaflush uses a lot of fluid so I suspect the cost of running it with the genuine ZF fluid would be prohibitivley expensive. 2012 TDV8 Vogue (L322) |
Yes, genuine fluid only for the final fill.
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 95 ![]() ![]() ![]() |
I've spent the last 3 months of emailing & leaving messages with Bodsy & as he's not got back to me have decided to do it myself. I have research the whole thing & as to a Megga flush vs partial oil change & new filter/pan I've come down with the thought that its best to do a partial genuine ZF oil change & filter and then in 12 months time just do another oil change without changing the filter of course. That should of changed at least three quarters of the oil. I will then have piece of mind that the filter & oil has all been done with genuine parts. I will also change some of the internal seals at the same which costs very little to do. But whoever you speak to has their own opinion on the subject, so I recon just replace like for like & you won't go far wrong. 2010 RR Autobiography 5.0 SC
