Home > Technical (L322) > Restricted Performance
CharlieF322
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Hello,
Got 2 codes this morning on the way to work and the usual restricted performance / limp mode.
I’m guessing it’s the intake donut hoses as they have been on and off a fair few times at a garage so probably worn out as they are the originals it seems.
Codes are:
P006A - MAF
P1247 - Turbo Underboost
P040D - EGR Temp (this one has always been there) no impact to performance though.
Has anyone had similar, and have a link to replacement hoses? Preferably silicone so they are stronger.
Thank you
2012
4.4TDV8
Westminster
Post #691522 29th Apr 2024 10:11am
JayGee
Do a forum search on the fault codes Wink
A 2012 car should have the updated hose connectors which are identifiable by the white lettering and are infact silicone. 2012 TDV8 Vogue (L322)
Post #691523 29th Apr 2024 10:48am
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
Should my 2011 FF have updated ones ? RR owner
Post #691531 29th Apr 2024 12:49pm
JayGee
Not from the factory but they may have been updated by a dealer or owner . They easy to identify as the old ones were moulded rubber with location slotts for teh hose clamps and teh new ones are smooth and shiny with white lettering. 2012 TDV8 Vogue (L322)
Post #691533 29th Apr 2024 1:17pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Donut hoses
Hi All
My 2012 TDV8 has the rubber hoses and have just ordered 500mm of 70mm internal dims silicon tubing as suggested on the forum. Would it be ok to used the existing clips or would new clips be required?
Many Thanks
Post #691584 30th Apr 2024 8:57am
BAZ8046
The existing clips work fine and are of good quality.
If you put them on the new pipe whilst cutting they act as a guide and help to get a straight cut.
My 2012 Westminster had the old style pipes on. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #691603 30th Apr 2024 1:50pm
Nylands
Hi Baz
That’s great then and thanks for the tip as well re fixing and the cut!
Cheers Thumbs Up
Post #691609 30th Apr 2024 3:54pm
Nylands
Silicon hose
Any idea of the length size needed for the four pipes. I'm not sure they are all the same on the n/s and o/side as expected?
Can replacement ones be purchased as I am expecting to have a garage change an oil cooler/ gaskets on my L322 and have them replace the tubes then as an alternative to the silicon tube I bought? I couldn't find a supplier when I looked. Question
Thanks
Post #691867 4th May 2024 10:26am
JayGee
They are all identical size. Someone posted the exact sizes on here a while back so do a search. Also don't forget the mod for the main intake to throttle body seal that is another weak point that leaks. 2012 TDV8 Vogue (L322)
Post #691873 4th May 2024 11:03am
PeteT80
Re: Silicon hose
Thanks
https://maltings4x4store.co.uk/search.php?...on=product
Post #691887 4th May 2024 12:46pm
Nylands
Thanks for the link Pete and I have the o rings for the throttle body seal job ready to do JayGee. No excuses but the weather today lead to yard work with a bit more to do.
Many thanks Bow down
Post #691920 4th May 2024 7:31pm
Nylands
JayGee
Can I ask about the removal of the throttle body connections please. Is the electrical connection to the nearest section easily separated and the actual hose readily available also if replacement becomes necessary?
Sorry to bother you but it all looks a bit tight and better to know how before starting.
Thanks again
Found the write up by Furnitureman covering the removal of hose and steps to seal the connection to the throttle body with the “o rings” he used. Figure then that after the hose is removed there is room enough to reach the electrical connection to the plastic part. Well done Furnitureman.
Great Forum!
Post #691960 5th May 2024 1:20pm
Nylands
Now what's holding me up?
Having been able to realign the hose clip attaching the hose to the plastic body (was almost down to the bottom of the hose) I'm almost there. Can someone enlighten me as to how disconnect the sensor plug though as big hands so far unable to pull that away, find something to unlock it?
I can now find some movement at the throttle body so be good to get the new o rings in place.
Thanks in anticipation.
Post #692143 8th May 2024 12:21pm
