Home > Maintenance & Mods (L405) > Oil Cooler Change - Miles to Service question
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, I have a query, I have just had the oil cooler replaced on my RR and obviously the engine oil and filter were replaced at the same time. Now I asked my indy whether they reset the service interval as the oil and filter has been changed and they said no as it is not a service they do not reset it, is this normal?
Now in the scheme of things I dont really mind as I am happy that the oil has been changed which helps with the whole dilution thing and also that I am not going to do that much mileage before it's next annual service where the oil will be changed again.
I am just curious as to whether when replacing the oil and filter yourself do you reset the service indicator so that the miles to service goes back up or not? _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #691882 4th May 2024 11:58am
Baltic Blue
I reset mine after each oil and filter change even though I only do a full service, air and pollen and fuel filters every 2nd year, because it resets the oil/ fuel dilution calculation figure, for the new oil to zero.
Post #691884 4th May 2024 12:08pm
ReggieMac
I was a little surprised that they didn't reset as I had intended to when I was about to change the oil myself but didn't bother as it was going in for the oil cooler replacement. Not sure whether I should reset it myself now or just leave it as is until it's annual service in November. Confused _______________________________________________
Post #691886 4th May 2024 12:12pm
caymanblack
it should be reset! do it yourself its easy. overfinch modified
Post #691915 4th May 2024 6:10pm
supershuttle
I just did an oil change (6months) and just reset mine. Have it done every 12 months at Indy and they do MOT as well. They also reset to service indicator, I think oil condition is probably the most important thing on a service so why not reset it. Geoff
Post #691921 4th May 2024 8:14pm
ReggieMac
So what would be the best way to reset miles to next service after changing the oil then? I have just tried to do it with an iCarSoft LR v3 and it wouldn't do it, error was 'failed to communicate'? Is there a better way to do it? _______________________________________________
Post #691977 5th May 2024 6:27pm
supershuttle
I think it's pretty well documented I did something that involved opening the bonnet, cycling the ignition, opening the drivers door and pressing both pedals, seemed to work with no gadgets involved. Geoff
Post #691988 5th May 2024 8:46pm
DrRob
Reset it. Oil dilution calculations have to be reset. They should know that.
An L405 can be done via some pedal combinations. Search on here or YouTube or invest in a gap IID Bluetooth Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #691990 5th May 2024 9:21pm
Kot
Service reset  2018 SE SDV8 4.4 Byron Blue
Post #691996 6th May 2024 9:29am
supershuttle
Well done Kot, I think I used this video- simples- no need to bother with IDTool or iCarSoftLRv3 (whatever that is) Geoff
Post #692017 6th May 2024 2:52pm
ReggieMac
Cheers Kot, followed the video, worked perfectly and mileage reset. I still dont understand why they did not reset when they knowingly had to change the oil but hey-ho, it is so easy to do now that I know I can do it myself. Thumbs Up _______________________________________________
Post #692021 6th May 2024 4:11pm
Changing the oil is only a small aspect of a service... There are many safety checks carried out at time of service and if the rest of the service and vital service checks were not carried out? Why would you expect a garage to reset the annual service light? Doesn't make sense to me sir...
Now if your mechanically savvy and understand the nuances with oil dilution etc etc, then I can understand why you would want the oil degradation meter resetting.
However, you must see the awkward position you would put the garage in, asking them to reset the service schedule having not carried out the rest of the service... No?
Post #692037 7th May 2024 12:14am
supershuttle
If (as I always do) change the oil more often than required I do a reset if for nothing else that to turn of the annoying warning every time I start the car. I get the car serviced and MOTd annually anyway.
Just to make it clear this is what I do it is not advice. Geoff
Post #692042 7th May 2024 7:22am
ReggieMac
I understand the garages point of view and it makes perfect sense and I am indeed only thinking about the oil dilution potential. I have an annual service regardless of mileage so that covers pretty much everything else. I was only really curious as I will be doing my own oil change between services and just wanted to know if there was any particular reason why I wouldn't reset the mileage indicator then? _______________________________________________
Post #692057 7th May 2024 11:21am
