![]() | Home > Maintenance & Mods (L322) > Maintaining my DPF this week |
jtq4u Member Since: 23 Aug 2023 Location: Portsmouth Posts: 37 ![]() ![]() ![]() |
I do wonder if garages ever use the right oil. No one would ever know.
When I have looked at the codes on a red error in the past I have also sometimes (always.. can't remember tbh) seen an insufficient flow from egr. Got round to taking the elbow pipe out this morning and no wonder why.. the bit that goes into the manifold has 8 holes apparently. There was only one that wasn't totally gummed up. I wonder if missing regens triggering red can then cause the high pressure diff error too. That won't help with my crap dpf capacity but I suspect it will stop the reds (as rr won't regen if there are egr issues as I recall)
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
The EGR valve is shut during regeneration so this won’t make any difference but it shows you have an issue with excessive soot if it’s blocked like that. 2012 TDV8 Vogue (L322) |
I think it does make a difference, as there are warnings on the forums that blanking off the EGR on the L322 4.4 stops regens.
Ok so 40 miles around the town still takes it from 13 grams soot to 23 and Amber warning. Including 2 missed regens.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1418 ![]() ![]() |
For L405 its as below, dont think there will be much difference on a L322? should be in the WSM be careful the regen will be inhibited very soon and never believe in linear!
Thanks.
What's your mpg in town and at a steady motorway cruise at 70ish? 2012 TDV8 Vogue (L322) |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 377 ![]() ![]() ![]() |
Following this with interest. I regularly get the amber warning. And a quick short m/way blast clears it for approx couple of hundred miles - I’ve started logging it to get accurate numbers. I’ve also started extending some regular journeys to include the short m/way trip. |
Very likley it will both fail a smoke test during the MOT and the ECU will throw a resticted performance warning as it will get out of range readings for the differential pressure sensor unless you have it mapped out. 2012 TDV8 Vogue (L322) |
The egr and dpf would get mapped out at the same time |
Around the town 19 to 21 Motorway cruise 32 to 34 |
That's pretty normal and nothing to suggest excessive fueling. 2012 TDV8 Vogue (L322) |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 200 ![]() ![]() ![]() |
Interesting post James and you're dead right, every time we change to a newer model it's a big learning curve.
