![]() | Home > Maintenance & Mods (L405) > can anyone help estimate cost for these on an L405 ? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
By the sounds of it, it's a vehicle you're interested in purchasing, in which case you shouldn't hold servicing items against the seller.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Budget £750-800 at an indy. Bit cheaper if using non OE spec parts |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1421 ![]() ![]() ![]() |
Mine had scored etc front discs from about the first service, it was agreed that the discs would be replaced when the pads were due for replacement and that happened at about 60,000 miles. Cost then included brake caliper refurbishment/replacement so total £1171
Sundayjumper Member Since: 15 May 2024 Location: Berkshire Posts: 15 ![]() ![]() ![]() |
Discs & pads are pretty easy to do - get your hands dirty and save a few hundred quid !
