![]() | Home > Technical (L322) > L322 In Tank Fuel Pump or Sender Wiring Failure |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 63 ![]() ![]() ![]() |
Is it the pump or just a faulty gauge wiring?
gone18751 Member Since: 28 Nov 2023 Location: None Posts: 17 ![]() ![]() |
That's a great question and I'm not sure. I broke down several months ago and recovered the car to a RR specialist. Since then I have made sure my tank is always half full.
I checked the search but couldn't find any info on this issue. |
Try these links,
Thanks a bunch for those links! |
AlexLRV8 Member Since: 16 Sep 2021 Location: Devon Posts: 14 ![]() ![]() ![]() |
There is a service bulletin about this somewhere. I had the same problem. It's caused by a faulty connector in the tank. I pulled the main pump, jet pump and senders out of the tank and cut off 2 or 3 connectors and soldered the wires together. Less than an hour and effectively a free fix. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Service bulletin
Thanks for that. I thought it was an issue with the in tank pump failing? Is this wiring issue the real cause of fuel starvation when there is a quarter tank or so of fuel? |
Yes.
