Home > Technical (L322) > Should I be worried?
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Doing the oil cooler on my new to me 2011 4.4, someone’s tried before with some form of sealant round the oil feed pipe into the cooler and rounded the nut off in the process, (that was fun) now I have the cooler off I’m greeted by this
Fairly sure this should be a nice smooth face??
It looks like the oil was leaking from the sealed up feed pipe and possibly the cooler itself, looking at where the oil was.
Should the above be of concern? Should I consider replacing it to?
Andy 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #692274 9th May 2024 9:12pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Here's what I found when I did mine:
I only replaced the gaskets & o-rings, and after 30 months and 25k miles, there's not been any issues or oil loss at all.
There does seem to be quite a bit of recent scratching in there - noticeable on yours that it's over the gasket marks meaning it's not from original production. However, the latest gaskets are larger (beefier) than the originals, so they might do the job there. That said, I'd be seeking another opinion from someone more knowledgeable than me! Thumbs Up The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #692283 10th May 2024 12:58am
kevinp
I think someone has at least tried to clean the surface but used too course a paper. I would block all the passage ways with kitchen towel and use a finer grade abrasive on a flat backing block. Thumbs Up
Post #692287 10th May 2024 9:08am
Andyyav
With the fear of making it worse I did nothing….
I could feel the new cooler assembly was siting nicely on the gasket (if that makes sense) and hoped for the best, so far so good but I guess time will tell
Changed the coolant reservoir surprised by the amount of sludge in the bottom of it, wondering if I should drain the coolant again in a week or so to give it a flush / clean out? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #692324 10th May 2024 10:06pm
