![]() | Home > Technical (L322) > Permanent fix for leaking throttle body pipe |
I can't rememberexactly how it comes off but don't recal this being a particularly difficult procedure so just work it out as you go along. 2012 TDV8 Vogue (L322) |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
I recently undid it with a thin flat head. Just stick from top but be careful. Use a thin one 2011 Vogue SE 4.4 TDV8 |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Many thanks for your response both and a good light and small screw driver shd do the trick then.
Just did mine again.....
Many thanks JayGee for the precise description on this job. Its a "restrictive space" for the plug mentioned but your comments have given me confidence to try that plug again. I did put a little silicone spray to it when last looked at it which will help. I'm glad that I didn't try to force it and think you might add an update when you try the new size O rings you ordered out.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 916 ![]() ![]() ![]() |
Well good news the o-ring fix is still holding up after 2000 miles ( circled in orange ) , I could only get 2 o-rings onto the throttle body ( not 3 as some people have managed)
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1315 ![]() ![]() ![]() |
There is a readily available seal for that.
Will order part LR022931
fmgl322 Member Since: 18 Apr 2022 Location: Koblenz Posts: 68 ![]() ![]() |
Finally got round to completing this handy little fix. I tried three O rings and found it was still quite a loose connection. I ended up getting a really tight fit with no less than 5 O rings (75x3). I also re-seated the green seal in the elbow before refitting - omitting the plastic ring as suggested. The whole thing now feels solid. There’s no movement whatsoever and initial tests would suggest it’s tight as a badger’s.
I did the fix with 3 Orings on the throttle body inlet hose and it feels solid, it does not move at all.
stefanstef01 Member Since: 11 Oct 2024 Location: Bucharest Posts: 3 ![]() ![]() ![]() |
I have the same problem. Mine started to leak to the bottom of the engine. Did you find the problem? |
