![]() | Home > Technical (L322) > Delayed Air Con |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7975 ![]() ![]() ![]() |
I think that will prob be different. This issue is no air con at all, then everything ok.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Thanks for that !!
Nice one. Glad you got it sorted.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Glad this was resurrected As my fairly new to me 09 (2010 MY) has been doing this and it really threw me as to why as I never had that issue in my 07. I’ll try a regas to make sure that is where it should be and if not, I guess I’ll be replacing the compressor too! 2009 (2010 MY) 5.0 Supercharged Autobiography
So was I ! It was about 120 or I think the wifey said but she got a loaner car ("her comment: "We'll definitely not buy a Renault!" ![]() ![]() I hope it'll solve your issue as well TDV8 Paul ! Cheers, Ard |
Thank you Dutchgit, my fingers are crossed when I get round to it at some point! 2009 (2010 MY) 5.0 Supercharged Autobiography
Make sure your aircon is turned off just in case the oil runs out of it completely.
miketrike Member Since: 24 Mar 2024 Location: birmingham Posts: 22 ![]() ![]() ![]() |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 949 ![]() ![]() ![]() |
Interesting, from cross referencing the part no LR056364
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 55 ![]() ![]() ![]() |
So my 2012 L322 Westminster has started doing a couple of odd things re the AC:
Sounds like the valve issue, though mine works nice and cold once it’s all got itself together…. So maybe you have 2 issues, but I think if you change the valve/compressor it will have to be re gassed anyway.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3297 ![]() ![]() ![]() |
Sounds like the compressor to me and similar to my symptoms. Depending on your budget you may want to get a few other items replaced like the belt and tensioners, waterpump, alternator etc as a lot of the labour involves removing the fan and shroud to get at it and these other items are then also replaceable. 2012 TDV8 Vogue (L322) |
