![]() | Home > General (L405) > SVO Premium Palette Grey |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
Yep, mine is SVO premium palette grey. Lovely colour and its not matt at all. In fact its got a bit of sparkle in it in bright sunlight. It was 4 years old when I got it in 2021 and I took it to James at ti22 for a detail and coating. Came back gleaming. I do the proper pressure wash/snow foam/two buckets thing to keep it clean and its still fine over 3 years later. In fact its the shiney black bits (backs of mirrors/window surrounds/rear 3/4 panels) which are a bit of a mare showing loads of scratches picked up off the hedgerows in the lanes. Mike - MPx
chrisnj Member Since: 21 Aug 2017 Location: Surrey / North Somerset / Florida Posts: 60 ![]() ![]() ![]() |
Thanks Mike that's good to know. Only seen photo's so far but hopefully going to see it in person tomorrow. I notice your's is a 2017. The one I'm looking at is an early 2017 so only has the wide upper screen update and still the analogue lower section. Is your's like that and what is the clarity of the upper screen like for satnav and cameras?
Mine first reg'd March 17 so also early. Has the wide screen at the top and seems absolutely fine to me for satnav and cameras - better than the one on my 2012 L322. Its better for seeing the tow ball to align it under the hitch although the proximity sensors pop up annoying blobs of colour obscuring some of the detail when getting close. The surround overhead pics can be really useful. One slight issue with the arrangement is if you ever try to set the satnav on the move. I find I try to steady myself on the dash before prodding the screen but you need to take care that none of the resting part of your hand touches the soft buttons on the bottom of the screen or you'll jump to that function and lose what you were doing. No problem if doing it as you should when stationary.
Thanks Mike, well I'm having a look at it tomorrow and lets see how it goes.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Mine is also an early 2017 AB I had the infomat system updated with the new maps it's better than the older maps,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
The SVO pallete Grey could come in matt or shiny from SVO... Just depends how it was ordered sir... Might be worth checking before viewing? ![]() |
Thanks Craig. I test drove the car yesterday. Fantastic drive and I think another 5.0L V8 will have to be the engine to replace the L322 for me. I still have to try a 4.4 V8 diesel and from what I've heard its a good engine but I think that maybe once you've had the 5.0L V8 its hard to have anything else. Fuel economy is not an issue for me and we don't tow at the moment.
