Home > Maintenance & Mods (L322) > Part numbers
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Part numbers
Anyone know the part numbers for the sunroof seal and the trims down the side of the rear tail gate glass?
I’ve searched about but nothing conclusive 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #692850 17th May 2024 12:17pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi,
The tailgate glass side rubber trims are DED500180 and DED500190. I replaced mine last week.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #692875 17th May 2024 10:04pm
dhallworth
The tailgate strips weren't on the earlier cars, they only appeared on the later ones. When the ones on my 2012 started to corrode and look scruffy I just removed them and didn't bother to replace them as the tailgate looks cleaner without them. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #692877 17th May 2024 10:59pm
Andyyav
RichTD6 wrote:
Hi,
Rich
Were they straightforward to replace? It looks like they just lever off? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #692878 17th May 2024 11:51pm
Andyyav
I assumed they had a purpose maybe part of a ‘sealing system’?
I guess you’ve not had any issues since removing them? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #692879 17th May 2024 11:53pm
RichTD6
They have a rubber tab on the lower end which was impossible to tuck back under the glass so I cut that off and pushed the strips onto each side of the glass. They fit tight enough without it and they haven’t moved since fitting them. Upper edge which tucks under the spoiler has some sealant already applied to the new rubber so just had to peel off the protective film on it and then press down firmly. You will see the rubber tabs I’m talking about when you get the new ones.
My understanding of these trims is they are to stop rain water running down on you off the edge of the glass when the tailgate is open. Certainly seems to do the trick and with my car being silver they definitely make the gap between the glass and the D pillars less noticeable, otherwise you could see the silver of the bodywork between. 2012 Westminster TDV8 4.4 Indus Silver
Post #692880 18th May 2024 12:10am
